Solving Water Flow from a Tank: Bernoulli's Theorem
In summary, the pressure at the bottom of the tank is atmospheric pressure and the distance where the cross sectional area is 0.9 times the area of the hole is 0.46m.
zorro
1,384
A tank is filled with water to a depth of 1m. A hole of cross section 1 cm^2 at the bottom allows the water to drain out. At what distance below the hole the cross sectional area of the stream is 0.9 times the area of the hole.
Applying Bernoulli's Theorem to the cross section of water stream just outside the hole to a depth 'x'
Patm + ρgh + 1/2 ρv1^2 = Patm + 1/2 ρv2^2
h=1m v1= (2gh)^0.5
v2=v1/0.9 (from equation of continuity)
On solving I got x as 0.46 m (app)
But the answer is 0.23 m
What is wrong?
Any ideas appreciated.
Hi Abdul Quadeer,
h=1m v1= (2gh)^0.5
Can you show how you got this number?
What is wrong?
I'm sorry, I missed one term on LHS
[Patm + ρgh] + ρgx + 1/2 ρv1^2 = Patm + 1/2 ρv2^2
i.e. g + gx + 2g/2 = 2g/(0.9)^2
2 + x = 2/(0.9)^2
or x=0.46m
On LHS I took [Patm + ρgh] as it is the total pressure acting at the hole (due to water column above it + Patm)
No, the [Patm + ρgh] is not right here. When the fluid is touching the air, as it is when it comes out of the hole, its pressure will be air pressure.
(If there were no hole, then the pressure at the bottom of the tank would be [Patm + ρgh]. In that case the bottom of the tank would be applying that much pressure on the liquid. But we know how much pressure air applies to something--the value of the air pressure.)
2 + x = 2/(0.9)^2
or x=0.46m
The fluid touches the air sideways, but it is in contact with the water in the tank vertically.
In the derivation of Bernoulli's Theorem, we take the pressure acting on the cross sections of the fluid (we do not consider any pressure acting sideways)
Refer my attachment.
Your figure shows the pressure acting on the cross sections, but that is also the pressure of the cross sections (that is, the fluid element at that point is pushing out in all directions at that pressure).
Notice that you have the pressure at the lower distance to also be atmospheric pressure. That is correct, and it is also not touching the air anywhere except its sides (above it there is only water).
Thankyou!
That cleared my doubt :smile:
Abdul Quadeer said:
Thankyou!
My pleasure!
What is Bernoulli's Theorem?
Bernoulli's Theorem states that in a steady flow of an incompressible and inviscid fluid, the total energy of the fluid remains constant. This means that as the speed of the fluid increases, its pressure decreases and vice versa.
How does Bernoulli's Theorem apply to solving water flow from a tank?
In the context of a tank, Bernoulli's Theorem can be used to calculate the flow rate of water as it exits the tank. By considering the change in velocity and pressure of the water as it flows, we can determine the rate at which water is leaving the tank.
What are the key assumptions of Bernoulli's Theorem?
The key assumptions of Bernoulli's Theorem are that the fluid is incompressible (its density remains constant), inviscid (there is no friction or resistance), and the flow is steady (the velocity and pressure do not change over time).
What are the units of measurement for Bernoulli's Theorem?
The units of measurement for Bernoulli's Theorem depend on the specific variables being measured. For example, pressure can be measured in units of Pascals (Pa), velocity in meters per second (m/s), and density in kilograms per cubic meter (kg/m^3).
How is Bernoulli's Theorem used in real-world applications?
Bernoulli's Theorem has many practical applications, such as in the design of airplane wings and race car spoilers, as well as in the study of fluid dynamics in pipes and channels. It is also used in the design of hydraulic systems and water turbines. Understanding Bernoulli's Theorem is crucial in many engineering and scientific fields.
