Fluids, flow velocity and flow rate.
Water flows from a container through a 50mm diameter hole at a rate of 36 liters per minute, which converts to a flow rate of 0.6 L/s. The initial calculation for flow velocity was incorrect due to unit errors. The correct formula for flow velocity is flow rate divided by the cross-sectional area of the hole, calculated as 0.6 L/s divided by π times the radius squared. After correcting the units, the flow velocity is determined to be 0.306 m/s. Accurate unit conversion is crucial for solving fluid dynamics problems.
Sum'Random
Water is flowing from a container through a 50mm diameter hole at 36 liters a minute. Calculate the flow rate in L/s and the flow velocity through the hole.
flow rate all i did was 36L/60s to get 0.6 L/s
flow velocity is where i am stuck.
Is it flow rate / Pi x r^2
So 0.6 / 0.00196 = 305.6 ms-1
missed a few classes due to illness typical most my assignment that is due was covered in them days i miss. Any help would be great.
Thanks
Hi, Sum'Random. Welcome to PF.
You have the right idea.
Watch those units. This is not the correct answer.
ohh i see what i missed, Thank you
0.6 / Pi x(0.025)^2
= 305.6
305.6/1000
=0.306 ms
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
