Calculating Shear Stress on Parallel Plates at 15 deg C
The discussion focuses on calculating shear stress in laminar flow between parallel plates at 15 degrees Celsius. The velocity distribution is given by the equation u/u_max = 1 - (2y/h)^2, with u_max set at 0.10 m/s and h at 0.25 mm. The shear stress on the upper plate is calculated using the formula τ_yx = μ (du/dy), with the dynamic viscosity μ at 1.14 x 10^-3 N*s/m^2. The temperature is converted to Kelvin as 288.15K for accurate calculations. The final calculated shear stress is -1.82 N/m^2, indicating the direction of the stress.
falcon0311
So I've got this velocity distribution for laminar flow between parallel plates.
\frac{u}{u_{max}} = 1 - (\frac{2y}{h})^2
h is the distance between the plates with the origin placed midway between the plates. I'm assuming this is for water flowing at 15 deg C with u_{max} = 0.10 m/s and h = 0.25 mm.
I'm supposed to calculate the shear stress on the upper plate and give its direction. I'm trying to figure out how to incorporate these into
\tau_{yx} = \mu \frac{du}{dy} at 15 deg C, \mu = 1.14*10^{-3} N*s/m^2 I also know the temperature has to be in Kelvin (288.15K in this case). Anyone willing to give me a push?
I've got it figured out. -1.82 N/m^2 = \tau_{yx}
seems correct
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
