Flux through a cube with non uniform electric field
The discussion centers on calculating electric flux through a cube in a non-uniform electric field. The electric field is defined as E = (-5 N/C x m) i + (3 N/C x m) k, where i and k represent the x and z directions, respectively. The key formula for flux is the integral of E dot dA, but the participants clarify that for each face of the cube, this simplifies to E multiplied by the area A due to constant dA across each face. The flux is computed by evaluating the electric field at the respective coordinates for each face and summing the contributions, particularly focusing on the faces aligned with the x and z axes. This approach provides a clearer method for solving the flux problem despite initial confusion over the electric field representation.
purplex76
This is really frusterating me, my book provides horrible examples and i have no idea how to go about this problem.
There is a cube with sides L= .3m and an electric field = (-5 N/C X m) x i +(3 N/C x m) z k i= i hat k= k hat
I know that the flux = the integral of the E . dA (dot product), but the form that i have for the electric field is not making sense to me.
How can i find the electric flux through the faces of a cube when i am given the electric field mentioned above?
I'm guessing a bit, but it sounds like the electric field at a point (x,y,z) is
-5 x Newtons/columb-meter in the \hat i direction, and
3 z Newtons/columb-meter in the \hat k direction.
Usually \hat i points in the x direction, \hat j points in the y direction, and \hat k points in the z direction. Does this sound right?
If so, it shouldn't be too hard to integrate the flux through a cube face...
i'm still lost
What pervect is trying to say in fewer words than I'm about to say is you have the field given by -5x + 3z. The flux is the integral of E dot dA right? However, since dA does not change on each face throughout the face E dot dA becomes E*A for each face. Sum the flux on each face up. I'll help you out with a little of the math:
The cube has one face facing the positive and negative directions for x, y and z. For example, the flux on the face pointing in the positive/negative x direction is <-5x, 0, 3z> * (0.3^2). The only difference is the value of x for each face, where <i, j, k> is a vector. Now sum up all 6 faces (you can ignore the ones facing the +y and -y directions)
