Flywheel effect on torque fluctuation of an IC engine
A flywheel reduces torque fluctuations in an internal combustion (IC) engine by increasing inertia, which stabilizes rotational speed and minimizes jolts to the drivetrain. While it does not change peak torque, the stored energy in the flywheel helps manage load variations by releasing energy when needed. The relationship between inertia and torque fluctuation is governed by the rate of change in acceleration, where greater inertia leads to smoother torque delivery. This stabilization can also improve engine idling performance. However, increasing inertia may impact overall engine performance, necessitating a balance between stability and efficiency.
Tec5nical
How does a flywheel reduce torque fluctuations in a IC engine?
Of course the more inertia you have, the less rotational speed fluctuation you get. But how does more inertia lead to less 'torque' fluctuation?
It doesn't. It does exactly what you said. :D
It's just lax wording.
Doesn't alter peak to peak torque, but the inertia means you don't get huge jolts on the drivetrain.
A flywheel is a rotating device which stores and releases energy when there variation in load requirement. Say if the load is enough then flywheel will store the energy and when the load is required the stored energy is released from flywheel.
The flywheel is a rotating device. It depends upon the moment of inertia ( mass x radius of gyration). The whole activities of the flywheel is controlled by its rotation causing the required moment of inertia to the load variation.
It is possible for a flywheel to reduce torque fluctuations in an IC engine. The reason behind this is that the rate change in acceleration \frac{d}{dt}\alpha(t) (Jerk), can be suppressed by imposing more inertia onto the crankshaft. This can also help your engine idle easier.
\begin{equation}
\frac{d}{dt}\alpha(t)I=\frac{d}{dt}T(t)
\end{equation}
From the above simple relation we can see that if we increase I (inertia) the rate change of torque onto the crank can be changed regardless of the acceleration. This problem can actually get very detailed. But the fundamentals are there.
Basically, your IC engine will produce a force which is translated into a torque as a function of time T(t). You can reduce the instantaneous acceleration \alpha(t) by changing the inertia.
This has however effects onto the performance of the engine etc.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
