Force exerted by a current carrying wire
A long wire carrying a current of 2.0A creates a magnetic field that affects a nearby electron with a charge of -1.6x10^-19 moving parallel to the wire at a distance of 0.01m and a velocity of 100km/s. The force acting on the electron is determined by the magnetic field generated by the wire, which can be found using the right-hand rule. The direction of the magnetic field curls around the wire, and the force on the electron is perpendicular to both its velocity and the magnetic field. Amperes law is suggested as a method to calculate the strength of the magnetic field. Overall, the discussion emphasizes understanding the relationship between current, magnetic fields, and the forces on charged particles.
Roodles01
A long thing wire carries a current of 2.0A.
An electron of charge -1.6x10^-19 moves parallel to the wire at a distance, d of 0.01m
The electron velocity is 100km/s.
State the magnitude & direction of the force acting on the electron.
Hmmm! Not really sure about this. Should I use Coulombs Law? Momentum. Newton's 2nd F=dp/dt
q1 q2 / 4∏εr2 rhat
Certainly Right hand rule.
The wire is not charged, Coulomb's law is not relevant.
Hint: The force comes from the magnetic field.
Well direction magnetic field of wire is found by the"right hand rule";
grab wire with thumb pointing in direction of current & mag field goes in direction of curl of fingers around the wire.
Then force is mutually perpendicular to v & B as I understand.
Good start I think. Yes?
I will try to put more down as I have time.
Ah! Amperes law I think to find strength of magnetic field. Yes or no.
That is the correct approach, right.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
