Force exerted on the palm of your hand by a beam of light
The discussion focuses on calculating the force exerted on the palm of the hand by a 1.0W flashlight beam, addressing two scenarios: when the light is absorbed and when it is reflected. The key formula used is E = pc, where E is energy, p is momentum, and c is the speed of light. The change in momentum for the reflected light is clarified as being twice that of the absorbed light, leading to a definitive understanding of the momentum change as 2P. The importance of consistent vector direction conventions in physics is also emphasized.
  • Understanding of the relationship between energy and momentum in physics
  • Familiarity with the principles of light reflection and absorption
  • Knowledge of vector quantities and their directional conventions
  • Basic grasp of force calculations in classical mechanics
  • Research the implications of light pressure in optical physics
  • Learn about the momentum transfer in photon interactions
  • Explore the concept of force in relation to energy and momentum
  • Study the applications of vector analysis in physics problems
Physics students, educators, and anyone interested in the mechanics of light and its interaction with matter, particularly in understanding force and momentum concepts.
Eric Diaz
Compute the force exerted on the palm of you hand by the beam from a 1.0W flashlight. (a) if your hand absorbs the light, and (b) if the light reflects from your hand.
What would the mass of the particle that exerts that same force in each case would be if you hold it at Earth's surface?
On the problem I used E = pc to solve part (a). My lack of understanding lies in part (b). Where I am told that the momentum change is twice the amount. I do not understand.
[P][/total] = [P][/1] + [P][/2]
Shouldn't [P][/1] cancel with [P][/2] since the momentum of [P][/2] is moving in the opposite direction?
The momentum was P and changed to be -P. Thus, the change in momentum was the change from +P to -P and that's 2P... The difference between 3 and -3 is 6.
So i should look at this as +P - (-P) = 2P ?
Yes.
Footnote:
Or you could look at it as (-P) - P = -2P, depending on whether you're defining the towards-your-hand direction to be the positive direction or the negative direction. Either way, the change in momentum is going to be the final momentum minus the initial momentum. The important thing with vector quantities like forces, momenta, velocities is that whatever convention you use, you use it consistently. Note that in this problem the force exerted on (and acceleration and resulting velocity of) your hand will have a positive sign under one convention and a negative sign under the other, but either way it will point from the palm to the back of your hand.
Nugatory said:
or (-P) - P = -2P, depending on whether you're defining the towards-your-hand direction to be the positive direction or the negative direction, but either way, the change in momentum is going to be the final momentum minus the initial momentum. The important thing with vector quantities like forces, momenta, velocities is that whatever convention you use, you use it consistently.
THANK YOU! I get it now.
40K
