Force Required to Maintain Conveyor Belt Speed: 7N
  • Thread starter Thread starter Antu Ghosh
    Belt Force
The discussion revolves around calculating the force required to maintain the speed of a conveyor belt with sand falling at a rate of 2 kg/s and moving at a constant speed of 3.5 m/s. The initial calculation using the equation F = v × (dm/dt) yields a force of 7N, which is confirmed to be correct. However, some participants suggest starting with a different equation that accounts for momentum changes, raising concerns about treating mass as a variable that can be created or destroyed. Alternative methods are proposed to address the force exerted by mass entering or leaving the system with velocity. The conversation highlights the complexities of applying physics equations in real-world scenarios.
Antu Ghosh
1. Problem Statement:
Sand is falling on a conveyor at a steady rate of 2kgs-¹.The motor of conveyor belt is rotating so that the belt is moving at a constant speed of 3.5m/s.what is force required to maintain the speed of the speed of the belt?
2. Relevant Equation:
F=v×(dm/dt)
F=(3.5)×2
=7N
F=v×(dm/dt)
F=(3.5)×2
=7N
Your numerical answer is correct. However I think you should start with ##F = \dot p = \dot mv + m\dot v##, and work from there.
Many, me included, object to that equation. In principle, it treats mass as something that can be created and destroyed, with momentum somehow being conserved. In reality, of course, it is entering or leaving the system to which p refers, and it may do so with momentum. The equation only works when it enters or leaves without momentum (as it does in this case).
You raise a good point. What is your preferred way to deal with situations like this?
Likes berkeman
One way is to consider the mass change as exerting a force. If the departing/entering mass does so with velocity vΔm then the force that exerts is ##\dot mv_{\Delta m}##. So ##\dot{(mv)} = F_{applied}-\dot mv_{\Delta m}##, or ##m\dot v = F_{applied}-\dot m(v-v_{\Delta m})##.
Not sure that is the conceptually clearest, though.
