Force on electron as it travels through conductor
The discussion revolves around calculating the force on an electron traveling near a straight conductor carrying an 18-A current. The initial attempt to find the magnetic field and force was incorrect due to the misapplication of formulas, particularly confusing centripetal force with magnetic force. Correctly applying Ampere's law, the magnetic field was recalculated, leading to a force magnitude of 2.57 x 10^-19 N. The direction of the magnetic force was clarified using the right-hand rule, emphasizing the need for a coordinate system to describe the force's orientation. The conversation also briefly touched on a separate question about nodal lines in an interference pattern, suggesting it should be addressed in a new thread.
NATSALANE
In a vacuum, a straight conductor has 18-A current that goes upward. An electron is traveling at 8.92 x 10^4 m/s. If the electron is 0.2 m from the conductor and its instantaneous velocity is parallel to the conductor (albeit heading downward), find the magnitude and direction of the force on the electron. Explain whether the force will be constant.
Here is my attempt:
Known:
I (current) = 18 A [upward]
v (speed) = 8.92 x 10^4 m/s
r (radius) = 0.2 m
q (charge) = 1.602 x 10^-19 C
Unknown:
Fe
F magnetic = F centripetal
qvB = (m x v^2) / r
Therefore,
B = mv / qr
= (9.11 x 10^-31) x (8.92 x 10^4) / (1.602 x 10^-19) x (0.20)
= 0.000002536 T
F magnetic = qvB sinTheta
= (1.602 x 10^-19) x (8.92 x 10^4) x 0.000002536 x sin90
= 3.6 x 10^-20 N
I think it went horribly, horribly wrong. Was I supposed to use to F magnetic equation at all? It's difficult to know which F equation to use.
I'd appreciate any guidance with this problem. Thank you.
It did go horribly wrong. The only field outside of the conductor is magnetic, but you can't assume that the electron is circling the conductor. It isn't. So your determination of B is wrong. You need to use Ampere's law to find the magnetic field around the conductor not 'centripetal force'. Once you understand what the magnetic field looks like, then yes, use q*(v x B) to find the force.
Thank you for your help. This is what I arrived at:
r (radius) = 0.2 m
B = μ0 [I/(2πr))
= 4π x 10^-7 [18 / (2 x π x 0.20)
= 1.8 x 10^-5
F nag. = qvB sinΘ
= (1.602x10^-19) x (8.92 x 10^4) x (1.8 x 10^-5) x sin90
= 2.57 x 10^-19 N
That's the magnitude of the force alright. How about direction?
This is another part where I am stuck. Since the magnetic force is perpendicular to both the velocity and the magnetic field B, would the direction of the force be towards the observer?
Toward the observer?? That can't be right. The observer could be anywhere. There are things called 'right hand rules' for remembering the relation between current flow and B field direction, and the directions of F and vxB. Look them up and try it out.
Using the right-hand rule, the thumb should be pointing up. Not sure which way to point the fingers, though... Would the direction of magnetic force be westward?
Westward?? You need a coordinate system. Suppose j points in the direction of current flow (so -j is the direction of v). Suppose i is the direction of a vector pointing from the axis of the conductor towards the electron. Now complete the system by picking the direction k using the right hand rule. Now describe directions in terms of i,j and k.
The direction is horizontal to conductor.
If that's right, maybe you can help me with another question:
Two sources that are placed 2.0 m apart operate at a frequency of 1.0 Hz. If the waves are 0.60 m, at what angles (from the centre line of the interference pattern) are nodal lines produced?
Known:
λ = 0.6 m
d = 2.0m
f = 1.0 Hz
Unknown:
angle θ
sin θ = (n – ½) x (λ /d)
= (1-½) x (0.6/2)
= 8.63°
Therefore, the nodal lines are produced 8.6° from the centre line of the interference pattern.
I don't know what direction "horizontal to conductor". The new question is entirely unrelated. I suggest you put it in a new thread.
