Force on electron travelling parallel to charge carrying longstraightwire
The discussion revolves around calculating the force acting on an electron moving parallel to a current-carrying wire. The magnetic field B produced by the wire is given by B = μ0I/2πr, where r is the distance from the center of the wire. The force on the electron is determined using F = qvB, with the charge of the electron being 1.6 x 10^-19 C. The direction of the force is perpendicular to both the velocity of the electron and the magnetic field, following the right-hand rule. The participants clarify that the radius used for calculations should be from the center of the wire, and the wire's circumference can be considered negligible.
zhillyz
An infinitely long straight wire of radius a = 0.01m carries a total current I = 1A
uniformly distributed over the area of the wire. An electron with instantaneous velocity (at time t ) v = 1000ms directed parallel to the wire (in the same direction as I ) is r = 0.1m away from the wire centre. What are the magnitude and direction of the force acting on the electron at time t due to the magnetic field B produced by the current?
F=qV x B
F=qV x B
=qvBsinθ
=qvB
B=μ0I/2∏r
My question is how to handle the radii? Would you calculate from the centre of the wire or the surface of the wire?
And in regards to the direction of the force if v is along the paper B would be into it and F would be down it.
Does this all seem correct?
First off, the electron will be directed in a helix around the wire moving parallel to the wire at a rate of 1000 m/s. The helix motion is caused by the magnetic force and the centrifugal force's equivalence. The direction of the force has to be perpendicular to the wire if you use the hand rule since the magnetic field around a wire is circular. The formula I would use to calculate the force is:
F = Bqv
The charge of an electron is 1.6*10-19
Of course you have to find the magnetic field before you can use this equation. The equation that you listed will work.
\frac{μ_{0}I}{2πR}
The permeability of free space (μ0) is about 4π*10-7 TmA-1
Use the radius given. The circumference of the wire is assumed to be negligible.
