Force required to push wheel (not torque)
To calculate the force required to push a 50 mm radius wheel with a moment of inertia of 3.21*10^-4 kgm^2 to 20 mph in 5 seconds, the initial torque calculation yielded 5.74 Nm. Using the equation F = T/r, the calculated force was 114.8 N, which seemed excessive compared to the vehicle's total mass. Upon reevaluation, an error was found in the torque calculation, leading to a corrected torque of 5.7*10^-5 Nm. This adjustment resulted in a more reasonable force requirement of 1.14 * 10^-3 N. The discussion highlights the importance of accurate torque calculations in determining the necessary force for acceleration.
Aerstz
How much force is required to push a wheel of radius 50 mm and moment of inertia 3.21*10^-4 kgm^2 to 20 mph in 5 seconds? The wheel has a mass of 0.29 kg.
The wheel is to be pushed straight and level at its axel 90 degrees to the horizontal.
T = Ia = 5.74 Nm
F = T/r
F = T/r = 5.74/0.05 = 114.8 N
My answer can't be correct because 114.8 N seems far too much force required to accelerate a 50 mm radius wheel to 20 mph in 5 s. That is less force required to push the 200 kg vehicle it supports, and there are another three wheels!
Never mind, I found my error. I failed to include the negative power value when calculating torque. Torque is 5.7*10^-5, not 5.7! Therefore the force required to push the wheel is just 1.14 * 10^-3 N, which makes much more sense.
Feel free to delete this thread.
T = Ia = 5.74 Nm
F = T/r
work done by force = acquired linear + rotational kinetic energies.
