Forces on an inclined plane, kinetic friction How is this wrong?
The problem involves two masses, m1 = 3.8 kg and m2 = 5.5 kg, connected by a cord over a pulley, with m1 on an inclined plane experiencing kinetic friction. The coefficient of kinetic friction is given as μk = 0.26. The objective is to determine the acceleration of the masses and the tension in the cord.
  • Mixed
  • Participants discuss the setup of equations for the forces acting on both masses, including tension, gravitational forces, and friction. There are suggestions to keep equations in variable form to avoid mistakes when substituting values.
Some participants have provided guidance on setting up the equations for both the x and y directions for the inclined mass, while others express uncertainty about solving the problem without knowing the acceleration. Multiple interpretations of the equations and the role of the normal force are being explored.
There is mention of the angle of inclination being 30 degrees, and some participants question the assumptions made regarding the normal force and its dependence on acceleration.
neutron star
In the figure below, m1 = 3.8 kg, m2 = 5.5 kg, and the coefficient of kinetic friction between the inclined plane and the 3.8-kg block is μk = 0.26. Find the magnitude of the acceleration of the masses and the tension in the cord.
http://img29.imageshack.us/img29/2676/0541.gif
5.5kg*10=55N
38 sin(30)=19N
(19N)(0.26)=5N
55-T=5.5a
+ T-19-5=3.8a
_______________
55-19-5=9.3a
39=9.3a
(divide both sides by 9.3)
a=3.333
(plug 3.333 in for a)
55-T=5.5(3.333)
55-T=18.33
-T=-36.67
T=36.67
a=3.333
T=36.67
How is this wrong? It says I am incorrect, why?
a =___ m/s2
T = ___ N
I would personally advise keeping the equations in the form of algebraic variables (m1/m2/g/a/T), then solving for the variables. When you get to more complicated problems, doing all of the necessary algebra before plugging in numbers makes it easier not to make mistakes.
neutron star said:
5.5kg*10=55N
38 sin(30)=19N
(19N)(0.26)=5N
55-T=5.5a
+ T-19-5=3.8a
You're rushing things a bit here. Make both x and y direction equations for m1. Make the +x direction along the plane of the slope going towards the pulley, and the y direction perpendicular to the slope.
The y direction equation for the box is:
N (normal force) - m1gcos(a) = 0
N = m1gcos(a)
The x direction for box m1 is:
T - m1gsin(a)-(μk)(N) = m1a1
For box m2:
m2g - T = m2a2
Now try combining, and then solve. (For this problem, assume a1 = a2, and the Tension is the same everywhere)
N = m1gcos(a)
For box m2:
m2g - T = m2a2
I don't think it's possible to solve that without having a.
You have:
T-38sin(a)-(0.26)(N)=3.8a
+ 55-T=5.5a
It would be 38sin(a)-(0.26)(N)+55=9.3a
You can't put in the normal force because you need acceleration to solve m1gcos(a) and you can't get rid of that 38sin(a). I'm guessing you meant 38sin(30).
You have:
+ 55-T=5.5a
Yes, sorry for not clarifying. The (a) inside the trig functions stood for the angle (30), and a1/a2 were the acelerations.
  • · Replies 22 ·
21K
  • · Replies 19 ·
