Solving for Unknown Force with Two Given Forces and Constant Velocity
  • Thread starter Thread starter shell4987
    Forces
To solve for the unknown force acting on a particle moving at constant velocity, it is essential to recognize that constant velocity implies zero acceleration. Consequently, the net force acting on the particle must also equal zero. Given one force, the other force must be equal in magnitude and opposite in direction to ensure the forces balance out. This understanding highlights the relationship between force, mass, and acceleration as described by Newton's second law, f=ma. The key takeaway is that the forces must cancel each other out to maintain the constant velocity of the particle.
shell4987
While two forces act on it, a particle is to move at the constant velocity = (3.9 m/s) - (-3.6 m/s). One of the forces is 1 = (1.446064618687 N) + (-5.679751753869 N). What is the other force?
f=ma
I don't know an equation to use with velocity in it that would work for this problem. Can someone help me out?
Since the particle is moving at constant velocity, there is no acceleration, therefore the net force or sum of forces = 0. The components of the other force must be equal in magitude and in the opposite directions.
The key point is that the velocity is constant. What does that tell you about the particle's acceleration and the net force on it?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
