Formula for average current on a coil inside a solenoid
The discussion focuses on calculating the average induced current in a small coil placed inside a solenoid. The solenoid, measuring 20.0 cm in length and consisting of 5000 coils, carries a steady current of 10.0 A. The initial magnetic flux through the inner coil is determined to be 8.88 x 10^-6 Wb, and the average induced EMF during a 15.0 ms interval is calculated as 0.059 V. The direction of the induced current in the small coil is counterclockwise (CCW) as the current in the solenoid drops to zero.
  • Understanding of electromagnetic induction principles
  • Familiarity with Ohm's Law
  • Knowledge of magnetic flux calculations
  • Basic proficiency in using the Biot-Savart Law for magnetic field calculations
  • Study the derivation of the formula for magnetic flux through a coil
  • Learn about Faraday's Law of Electromagnetic Induction
  • Explore the application of Lenz's Law in determining the direction of induced currents
  • Investigate the effects of resistance on induced current in circuits
Students studying electromagnetism, physics educators, and anyone interested in understanding the principles of induced currents in coils and solenoids.
starthorn
A solenoid of length 20.0 cm is made of 5000 circular coils. It carries a steady current of 10.0 A. Near its center is places a very flat and small coil with a resistance of 2.50 Ω made of 100 circular loops, each with a radius of 3.00 mm. This small coil is oriented so that its area receives the maximum magnetic flux. A switch is opened in the solenoid circuit and its current drops to 0 in 15.0 ms. (a)What is the initial magnetic flux through the inner coil? (b) Determine the average induced EMF in the small coil during the 15.0 ms. (c) If you look along the long axis of the solenoid so that the official 10.0 A current is clockwise, determine the direction of the induced current in the small inner coil during the time that the current drops to zero. (d) What is the magnitude of the average induced current in the coil?
I don't know which equation I need!
I have solved everything up until part d. I don't know which equation I need to use to find the average induced current in the inner coil.
This is what I have done for parts a through c:
a) B=μnI
B= 4∏x10^-7(5000/.200)10.0= 0.31416 F
[itex]\Phi[/itex]=BAcosθ
0.31416(∏0.003^2)cos(0)= 8.88x10^-6 Wb
b) [ε]=-N(Δ[itex]\Phi[/itex]/Δt)
-100(8.88x10^-6/0.015)= 0.059 V
c) CCW
Thanks so much for your help! And if you wouldn't mind checking the parts I completed I would be so grateful!
For (d) use your result from (b) and the given resistance of the coil. Think Ohm's law.
You might want to reconsider your answer to (c). Note, in this problem the flux through the coil decreases when the switch is opened.
Haha of course! I feel silly for not thinking of that. Thanks so much TSny!
