Formula of an inverse function
wertlewoo2
Find the formula of the inverse function of f(x)=300/(3+15e^.05x).
I'm definitely way off but I got .05y(5x)+ln100=lnx. What I did was multiple the denominator by the y(cross mltiplication) and then tried to factor out e.
Welcome to PF!
So you start with y = 300 / (3 + 15 e^(x/20)
and do the cross product trick to get y * (3 + 15e^(x/20)) = 300
and then to:
3 + 15e^(x/20) = 300 / y
Does this help?
You should now move terms and factors to the y side and you should then be able to isolate everything
so that you get x = ...
@Jedishrfu Thanks so much that was really helpful! Last question do you know how you could be able to take the ln of e to simplify the equation?
I'm sure he does. The real question is do you know how? If you do, take a stab at it.
If you don't, review the properties of logarithms.
:smile:
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
