Is Free Will a Foundational Assumption in Quantum Theory?
In summary, the "free will" assumption is not a foundational assumption of QM. It is an assumption of the scientific method. The superdeterminism alternative to the theory of free will undermines all of science.
Lynch101
83
TL;DR Summary
Is "free will", as it is usually interpreted, a foundational assumption of QM?
Summary: Is "free will", as it is usually interpreted, a foundational assumption of QM?
I've done a search using the term "free will" and have done a ctrl+f "free will" to go through those threads but I feel that the best way to find definitive clarification on my question is to ask specific, targeted questions in a separate thread. The specific questions I have are:
1) Is "free will" a foundational assumption in Quantum Theory?
I've read a few different things about the notion of Free Will in Bell's Theorem and have read a few articles about "closing the free will loophole". In this video the author suggests that Bell's Theorem implies that we must give up our notions of either Realism, Locality, Local and Realism, or Free Will. Is it fair to say then that [the generally understood notion of] Free Will is a foundational assumption in QT?
2) Is Free Will a foundational assumption of the scientific method?
In reading up on Free Will in Quantum Theory, I have come across the notion that Free Will is a foundational assumption in the practice of sicence itself. Is this the case?
2) If there is no "free will", does that mean that the universe must be superdeterministic?
I'm not particularly interested in the implications of superdeterminism, or what it necessitates, I'm just interested in the the necessity of it as a conclusion, if Free Will does not exist.
In the Bell theorem, the "free will" assumption is really the assumption that there is no correlation between the choices of which observable will be measured on different subsystems. So yes, it is an assumption of the Bell theorem, but it is not directly related to the usual psychological notion of free will.
Likes Abhishek11235, Stephen Tashi, Lynch101 and 2 others
It has always seemed to me that "free will" in the psychological sense is a red herring when it comes to science. It doesn't really matter whether
a) I am a complex system that is capable of a large number of, for all practical purposes, unpredictable actions.
b) There is some external or internal additional factor (free will, consciousness whatever) that determines what I do.
If we take a simple example. I decide to test the theory that a rubber ball bounces differently off a hard floor and a carpet. I carry out this experiment and record the results.
It doesn't really matter, IMHO, whether or not it was inevitable that I should do this. I did the experiment and recorded the results. That's all that matters.
Superdeterminism goes much further and, essentially, undermines all of science. It feels to me like clutching at philosphical straws to avoid the difficult conclusions of QM.
For example, a superdeterministic alternative to the theory that a rubber ball bounces better off a hard floor goes as follows:
1) Rubber balls bounce high or low depending on an internal parameter.
2) This parameter is correlated with all humans brains and where they decide to bounce a ball.
3) Whenever the ball is programmed to bounce high, the human is programmed to bounce the ball on a hard surface.
4) Whenever the ball is programmed to bounce low, the human is programmed to bounce the ball on a carpet.
The QM version is, no doubt, more sophisticated; but, that's the gist of it, as far as I understand it.
Likes hutchphd, Lynch101, forcefield and 3 others
That's pretty much it in QM as well actually. Say in a CHSH test we are looking at the sum of correlators:
$$\left<AB\right> + \left<BC\right> + \left<CD\right> - \left<AD\right>$$
As you know this is meant to ##\leq 2## for a local classical theory. In a superdeterminisitic theory any time ##AD## is negative we are predestined to measure it. And any time the other pairs are positive we are predestined to measure one of them.
The only sophistication is that technically it need not be all of time just "enough" to tip the sum over ##2##.
Likes Lynch101 and PeroK
Thanks for the reply Demystifier. I was thinking that it mustn't necessarily be the usual psychological notion of free will but I have seen various quotes from mathematicians and physicists that seem to strongly imply that it is Free Will as we usually think of it.
Would you be able to clarify what it means "that there is no correlation between the choices of which observable will be measured on different subsystems". Is this essentially saying that the choice of which observable is measured is not a deterministic process? Or that there is no common cause in the past history of the experimenters?
Just to try and understand the opposite which might help me to understand the point, what would it take for us to say that there was correlation between the choices?
I guess it doesn't really affect how science is done bcos science is being done whichever scenario is true. But, to have a complete description of the Universe it would be a material concern (no pun in 10 did).
Let ##c_1## and ##c_2## be the two choices and let ##p(c_1,c_2)## be the probability of the joint choice ##c_1## and ##c_2##. The claim that the two choices are not correlated means that there exist probabilities ##p_1(c_1)## and ##p_2(c_2)## such that
$$p(c_1,c_2)=p_1(c_1)p_2(c_2)$$
Here all probabilities are defined in terms of relative frequencies and it does not exclude the possibility that the fundamental microscopic dynamics is deterministic (but too complex or chaotic to make deterministic predictions in practice).
Conversely, if the joint probability cannot be written in the product form above, then the choices are correlated. In other words, the choices are not statistically independent.
Likes Lynch101, forcefield and PeroK
No, IMHO the perfect correlation in the Bell experiment is a kind of superdeterminism. One can always try to explain the weird correlation away, for example through FTL influence (without free will).
Likes Lynch101
Again, thanks for the explanation. I think that I follow it - up to a point. Are there cases where the choices are correlated and cases where they are not? Or is that a subject of debate?
Is it known what would be the cause of it not being possible to write the joint probability in the product form above?
Apologies also, I keep trying to bring it back to terms that I understand better such as determinism, indeterminism, and Free Will. Am I right in saying that the if the probability function can be written in the product form above, then there is determinism. If it can't, then the Universe can't be deterministic and is possibly non-local?
No, that's completely wrong. What made you think that?
One problem is that you are trying to run before you walk. You are trying to debate the big, philosophical issues around QM without understanding the basics.
Regarding determinism in QM you should first study electron spin and the Stern-Gerlach experiment. Then you can move on to two particle entangled systems and then to the Bell theorem.
At that point you may understand the remaining philosophical wriggle room in terms of super determinism.
Likes Demystifier
I think "free will" as far as it is relevant for physics is another word for the rejection of superdeterminism.
Superdeterminism is simply conspiracy theory extrapolated into complete absurdity and is reasonably rejected. But the base for the rejection of superdeterminism is not some physical theory - classical or quantum - but metatheoretical. Without a rejection of superdeterminism, there would be no longer any base for doing any statistical experiments at all. Whatever the result of such an experiment, it would be possible to explain it away with some super-conspiracy.
It is the other way. Superdeterminism is the ultimate way to explain away any weird correlation, without any further necessity to care about it. Explanations through FTL influence are, instead, nontrivial, they require nontrivial modifications of existing theory (introduction of a preferred frame, if one wants to preserve a notion of causality).
Science is impossible if weird correlations do not define nontrivial scientific problems. So, superdeterminism taken seriously would be the end of science.
The tobacco industry would be happy to use superdeterminism to explain away correlations between smoking and lung cancer. They would have to do nothing - the word "superdeterminism" would be already sufficient. Now they have to invent something else to explain these correlations away. But whatever they propose, it would have to be a scientific theory which makes predictions, and it would have one particular feature - that taking into account all common cause explanations, the remaining correlation would have to be zero. Which could be easily falsified by yet another statistical study.
Likes Demystifier and PeroK
To paraphrase Rutherford, it would be the end of physics, but we would still have stamp collecting. In other words, we would still have useful collecting of data telling us what is correlated with what. We would just not have any theory behind it.
Likes Swamp Thing, Lynch101 and PeroK
And before that I would suggest to study classical deterministic chaos and generators of pseudorandom numbers.
Likes Lynch101
Probably not the first time or the last time that will be the case :p
It might be helpful to outline where my particular interest lies. I am currently working on a piece of writing that may touch on the notion of "Free Will" and so I'd like to develop a better understanding of what it means or the role it plays in physics.
The confusion, perhaps, arises from the use of the term "Free Will". I have read a number of quotes from different sources, most notably Bell himself and John Conway [of the "Free Will" theorem]. The quotes pretty unequivocally, reference the common sense notion of "Free Will". For example:
John Bell said:
There is a way to escape the inference of superluminal speeds and spooky action at a distance. But it involves absolute determinism in the universe, the complete absence of free will. Suppose the world is super-deterministic, with not just inanimate nature running on behind-the-scenes clockwork, but with our behavior, including our belief that we are free to choose to do one experiment rather than another, absolutely predetermined, including the "decision" by the experimenter to carry out one set of measurements rather than another, the difficulty disappears.
I've heard arguments put forward, as above, that it isn't the common sense notion of "Free Will" that is actually meant but rather just the idea of indeterminism and the idea that the future is not predetermined. Others still, say that it - the common sense notion of "Free Will" - is a fundamental assumption of Bell's theorem. There almost seems to be some implication that "Free Will" is what gives rise to indeterminism.I'll outline what made me think that from your post above
I was thinking that the probability function reflects the myriad physical elements that affect the possible outcomes. In this case determinism isn't ruled out. It might be the case, however, that it is too complex or chaotic to make deterministic predictions in practice.
Saying that this means that "there is determinism" is probably too strong, but I took it to be the case, given the alternative.
With this I am inferring, possibly incorrectly, that if the joint probability cannot be written in the product form outlined, then there must be an aspect of the physical world, which is not present (or maybe accounted for) in the case where the probability can be written in that form, which leads to the choices being correlated.
I must be wrong in my conclusion that this second option represents an indeterministic universe.I am taking the probability function to be a representation of the various elements in the physical world which can affect the possible outcomes, so if the probability is different in each case, the difference must be attributable to an element of the physical world. That is just my thinking.When I think of determinism, I think of a long unbroken chain of causality, where every effect can be directly traced to it's preceding causes. In this case, the common understanding of the notion of "Free Will" is invalidated.
Thanks Perok. I have looked at all of those but I wouldn't claim to understand every aspect of them. I may have reached the limit of my understanding in that regard. I know that this is obviously a major impediment to understanding QM, which is why I try to use the things I think I understand as an inroad.
Is there any particular element of Stern-Gerlach that pertains to the "Free Will" or "Free Choice" assumption? Just to try and narrow down my search
You're missing the point. Even if the universe is completely deterministic, there is no correlation between certain data.
For example, suppose you and I in separate rooms wrote down a sequence of numbers.
Determinism might suggest that both sequences were inevitable from the big bang. But not that they are correlated.
If we find that the sequences are always the same, then that requires a different explanation. Determinism alone cannot achieve that.
Why would you and I always write the same numbers in a sequence? it doesn't matter that both sequences were determined at the big bang. Why are they the same?
Superdeterminism goes further - and further than Bell hints in what he says. In order to explain QM through superdeterminism you have the equivalent of a god who is playing tricks on us.
If you don't already know that you are not in a position to debate QM! Sorry, but that's the hard truth.
Do you have any formal education in probability and statistics?
Thank you Elias, this is essentially one of the questions I had. If "Free Will" is the rejection of superdeterminism, what is meant by that term "Free Will"; is it the common sense notion of "Free Will"?
Would the negation of "Free Will" - whatever it's meaning - imply that the Universe is superdeterministic?
I don't want to get into the particulars of superdeterminism because I think it usually leads to threads getting closed. It is also a different idea that I will probably need to focus on, by itself to understand all the conspiratorial implications. I want to try and wrap my head around the notion of "Free Will" first, as it appears in the context of Quantum Mechanics.
Only as far as High School unfortunately.
Just to test your understanding, can you give examples of two mutually correlated and two mutually uncorrelated phenomena from everyday life?
Likes Lynch101
That's fair enough. I guess I don't see it as debating QM but trying to clarify a commonly understood term as it appears in the context of QM. I think I have a fairly decent grasp on the notion of determinism - if there isn't more to it than I understand. "Free Will" is a commonly understood, if ill defined, term and it appears to be this that is often referenced in the literature.
Indeterminism is probably a lot less intuitive but it can be spoken of in terms of the common sense idea of "Free Will" and I am familiar with the notion of indeterminism in QM.
Would you be able to direct me to the part that is relevant to "Free Will"? I often find that when I read explanations of these different experiments, I can follow generally what they describe but I require the commentary to highlight the consequences.
Thanks Demsystifier, this is very helpful.
I'm not very familair with the term mutually correlated phenomena. I would be coming from the other side hoping for examples to clarify the meaning of the term.
The examples that come to mind are those that I have encountered in the explanation of Bell's theorem, such as the case of a machine sending out 2 or 3 balls to different roulette tables.
I'm afraid coming from the other side (Bell theorem in this case) would not be a good idea. You have to first learn basic concepts (and the concept of correlation is very basic in this context) on less abstract examples. Trying to understand Bell theorem without understanding the concept of correlation first is like trying to understand square root (e.g. ##\sqrt{427}\approx 20.66397832##) without understanding addition first (e.g. ##2+3=5##). Sorry, but it simply won't work.
Likes PeroK
I would say no. Superdeterminism is essentially a completely absurd idea. Bell has mentioned it simply to reject it with quite trivial arguments. So, rejecting superdeterminism is essentially rejecting nothing but a complete absurdity. Common sense free will is something more specific. If, say, free will is compatible with fatalism or classical determinism is something people argue about.
So, my description of "free will is rejection of superdeterminism" is restricted to its use in discussions of quantum foundations and in particular Bell's theorem.
How would you know? There is no unified framework or vision how the universe/reality works. Just remarkable bits and pieces which make correct predictions - sometimes at odds with perception and intuition. If 'matter' is emergent(i.e. not fundamental - easy to swallow given the principles of qm) and space and time are also emergent(see Witten et al, string theory, LQG, background independence...), then determinism and causality are also emergent.
Likes Lynch101
I appreciate that but I don't think that it's a case that I don't understand the concept of correlation, I'm saying that I don't necessarily understand the term "mutually correlated phenomena". I think I might be making this a little harder on myself than I should be. I'm assuming that I don't understand that term, when maybe I do. I understand correlation in the sense of two things occurring at the same time but neither necessarily being the cause of each other.
I'm having trouble coming up with a decent example, something like the number of flowers that bloom in summer and the number of people wearing sunglasses - is that along the lines of what you mean?
I sometimes feel it's like learning a language. It's not that I don't understand the thing being talked about, its that I'm not certain of the terms being used - of course that is not the case in every question.
Likes Demystifier
Yes, that's a nice example of two mutually correlated phenomena.
Likes Lynch101
That does appear to be the consensus. I haven't tried to look at it in depth yet. It sounds to me like the idea of determinism but just extrapolated to it's logical conclusion - but I'm assuming there must be more to it than this, given what I hear about the conspiratorial nature. I'll definitely look into it more at a later point to try and understand it better.
John Conway [of the Conway-Kochen-Specker theorem] talks unequivocally about "Free Will" in the common sense form of the idea.
It's that use of the term "Free Will" that I'm hoping to understand better, as it pertains to quantum foundations and Bell's theorem. Is there any sense in which the common sense notion is related to the usage in QM foundations?
  • #31
My apologies! I know it probably makes things even more frustrating when someone doesn't even realize they understand certain basics. I've kind of gotten into a habit of presuming there must be a more complicated meaning to most terms I meet
Likes Demystifier
  • #32
Thank you Perok, this explanation has helped to clarify the question a little further, particularly the question "why are they the same?"
Are they the same every time, or just the same when a particular question is asked? Say, if we are both asked to write a sequence of prime numbers, we will always write the same?
I have seen that there are 4 possible answers to this question, namely that they involve giving up either:
1) Realism
2) Locality
3) Locality and Realism
4) Free Will
It's the 4th option I'm trying to get a handle on. If it isn't Free Will in the sense that it is commonly understood, what is a more precise interpretation of it? Is it "simply" indeterminism or the notion that the future is open and not predetermined? If we look backward in time, would such a universe appear to be deterministic?
  • #33
1) Realism
2) Locality
4) Free Will
Let's assume that the numbers are always all the same. So, we decide we do not have "free will". Then we decide to let some outside agency decide for us. We'll count the cars going past our labs in a specified minute, say.
Every day, at 12 noon, we do this. We both agree, by the way, that we had no choice: that this decision was inevitable from the big bang. No free will in any of this.
Now, what if the numbers are still the same? Why does you and I having no free will mean that the number of cars passing our respective laboratories is correlated?
Getting rid of free will does not help in the case of QM and Bell's theorem, because the experimenters can decide to use an outside agency to decide on a measurement angle.
It's not enough that we had no choice to use these data sources. That doesn't explain why the data sources we did choose are correlated in any way that is meaningful to our experiment.
To explain QM you must, in this case, employ some superdeterministic theory that correlates data that have no good reason to be correlated.
Likes Lynch101
  • #34
To add to my post above. Let's simplify things and have us roll dice instead. You can if you wish check that:
You get 1-6 with equal frequency ( I.e probability) and I get 1-6 also with equal probability.
You can also check that our dice rolls are independent and uncorrelated. That means the equation posted earlier by @Demystifier is satisfied.
This is the basis of applying probability theory, as it is applied in Bell's theorem.
If we use this data (our dice rolls) to make decisions in a QM experiment that leads to an "unexpected" correlation in the results of that experiment. Then either we accept the correlation is inherent in the experiment. Or, we reject the lack of correlation in the dice rolling. This latter idea is not the loss of free will, but superdeterminism: somehow everything in the universe conspires to produce data that looks uncorrelated on one level, but at some other level is deeply correlated.
It's nothing to do with free will, per se.
Likes zonde and Lynch101
  • #35
I think Free Will has to be a foundational assumption in Quantum Theory for a couple of reasons.
1. The Experimenter's choice has to be a free choice or there would be some hidden variable that determines what measurement can or can't occur prior to an experiment taking place. This is essentially the Free Will Theorem and the Strong Free Will Theorem. If, as the Experimenter, my choice is predetermined, then this information has to be relayed to the quantum system prior to any measurement occurring.
2. We have a free choice but that choice is limited by what outcomes can occur. So I can roll a pair of dice a gazillion times and at the end of the day I can only roll a 2-12. So the question is, how restrained are the outcomes that can occur that are allowed by the initial conditions of the universe.
We see a universe filled with planets, galaxies, stars, black holes, comets and more but these things occur again and again. NASA was saying when it comes to exoplanets, the universe favors smaller Earth sized planets. The question is, how fine tuned or how random are the initial conditions that determine what outcomes can or can't occur. Are we looking at an infinity of universes that's similar to ours which would suggest the outcomes that can occur are very restrained or are we looking at 10^500 false vacua that would allow for an almost infinite set of initial conditions that can occur. The probabilities that can occur in QM seem to be restrained as to the frequency of there occurrence just like a 7 has the probability of occurring more frequently than a 2 as you keep rolling the dice or a 3 of a kind has the probability of occurring more frequently than a full house as you play more games of Poker.
Likes Lynch101
  • Quantum Interpretations and Foundations
25
30K
11K
