Frequency of AC circuit with inductor
etagg
The voltage across and inductor reaches its maximum value 22ms before the current supplied by the generator reaches its maximum value. What is the lowest possible frequency at which the generator operates?
I used the equation V=V_(max)sin(wt+90), where w is the angular speed equal to 2pi(f), where f is the frequency of the generator.
I also used the equation I=I_(max)sin(w(t+22ms))=I_(max)
I recognized that the voltage across an inductor has its maximum value when sin(wt+90)=1, or wt+90=90. This obviously means that wt=0, and i could not get a frequency from that.
I then looked at when the current is maximal, or when w(t+22ms)=90, and again i got stuck.
I think I am missing something simple.
Do you know that the voltage across an inductor leads the current by 90 degrees? What does that tell you about the period of oscillation
Well i knew that the voltage across and inductor leads by 90 degrees, which is why i used the equation V=V_(max)sin(wt+90).
If the voltage leads the current by 90 degrees, it means that when the voltage is a maximum the current is zero. I am not sure how that would help me?
Well, it tells you that 90 degrees of rotation takes 22 ms. How long does it take for a complete revolution? What is the corresponding frequency?
ohhh so then the full rotation is 4*22s= 88s and then divided by two pi is the frequency? Thanks so much for your help jdstokes
Actually, frequency is just 1 over the period which you found to be 88 s. Angular frequency is the number of radias per second, ie 2*pi*frequency. But you have the idea.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
