What is the frictional force at constant velocity?
When a 10 N force is applied to a cart moving at constant velocity, the frictional force must equal the applied force to maintain equilibrium, resulting in a frictional force of 10 N acting in the opposite direction. Newton's second law indicates that with zero acceleration, the net force is zero, meaning all forces must balance. The discussion clarifies that both static and kinetic friction concepts are relevant, but the key point is that the frictional force matches the applied force when velocity is constant. The forces acting on the cart include weight, normal force, applied force, and friction force, which cancel each other out. Understanding this balance resolves the confusion regarding the frictional force's magnitude.
moonbase
A 10 N force is horizontally applied to a cart from the left. The cart moves to the right with a constant velocity. What is the magnitude and direction of the frictional force? (In terms of mass)
Fnet=ma
fk=ukN
I know Newton's second law shouldn't apply since the acceleration equals zero so there is no net force. But I'm confused as to how I can get all the forces to cancel out if the applied force needs to be greater than the frictional force in order for the cart to move. So the frictional force can't be 10 N. Is there a force I'm missing or is there something wrong with my reasoning?
Fnet=ma
fk=ukN
I know Newton's second law shouldn't apply since the acceleration equals zero so there is no net force. But I'm confused as to how I can get all the forces to cancel out if the applied force needs to be greater than the frictional force in order for the cart to move. So the frictional force can't be 10 N. Is there are force I'm missing or is there something wrong with my reasoning?
your problem lies in the statement in red, above.
You do, and have, used Newton's second law when you concluded "... so there is no net force".
getting all the forces to cancel out is easy ...
Weight down
Normal Reaction Force up
Applied Force to the right [applied from the left]
Friction Force to the left.
They cancel in pairs.
Oh okay, I was getting static and kinetic friction mixed up. Thanks
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
