Frictional Force on 39 kg Mass on Inclined Plane
The discussion centers on calculating the frictional force acting on a 39 kg mass resting on a 32-degree inclined plane, with static and kinetic friction coefficients of 0.73 and 0.62, respectively. It emphasizes that the frictional force cannot be zero, as gravity continuously exerts a force on the block, necessitating a counteractive normal force. The normal force on an incline is determined by the formula mgcos(θ), rather than simply mg. To find the frictional force, one must use the equation F_friction = μ_s * F_N, where F_N is the normal force. The conversation also touches on the need to understand the geometry of forces acting on the block to solve for the largest angle before sliding occurs.
kiwikahuna
A block is at rest on the incline (32 degrees from the horizontal). The coefficients of static and kinetic friction are Us=0.73 and Uk=0.62 respectively. The acceleration of gravity is 9.8 m/s^2. What is the frictional force acting on the 39 kg mass?
PART 2: What is the largest angle which the incline can have so that the mass does not slide down the incline?
force of friction = (Uk) Fn
force of friction = (Us) Fn
My initial thought was that the frictional force would be 0 because the block is at rest?
I have no idea how to start part 2 either. Please help if you can!
First, start out by drawing a diagram with all the forces that are acting on the block. Figure where the normal force, force of gravity, and frictional forces fit in.
As far as your thought about it being zero goes, think about simply standing on the floor. Sure you are not moving, but since gravity is perpetually acting on you, then what prevents gravity from not pushing you through? A counter-active force, which you probably know as the normal force. How do you think this extends to the block?
So if the normal force is 39 X 9.8 m/s^2 = 382.2 N
how can the frictional force be found? Sorry if this is such a simple question, I'm really lost though.
Ah, so there is one problem already. In this case, the normal force is not actually mg because it is on an incline. The normal force is actually mgcosØ, which can be found through geometry because the gravitational force will point straight downwards, but the normal force is perpendicular to the plane (the incline) and will form an angle relative to the gravitation force.
You should verify this geometry and work it out yourself as you will need it for actually determining the force of friction acting on the block.
F_{fs} = (F_N)(\mu_{s})
Because of this relation the friction force cannot be zero because the force of gravity is acting on the system, which inturn affects the normal force, which affects the friction force.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
