Frictionless inclined plane physics homework
A 2.0 kg mass slides down a frictionless inclined plane at a 30-degree angle, starting from rest, and the goal is to determine its speed after sliding 3.0 m. The initial force calculation of 4.9 N was incorrect because the mass was not included in the force equation. The correct force should be calculated using F = mg sin(theta), which results in a different value. The work done on the mass, W = Fd, should also reflect this correction. The final speed calculation must incorporate the accurate force to yield the correct result.
IB
A 2.0 kg mass slides down a frictionless inclined plane that makes an angle of 30 degrees with the horizontal. The sass starts from rest. What is its speed after it has slid a distance of 3.0 m along the incline?
I got:
F = (sin30)(9.8)
F = 4.9 N
W = Fd
W = (4.9) (3) = 14.7 J
W = E_kin
14.7 J = 1/2 mv^2
v = 1.21 m/s
Is my method correct? I'm very unsure how to do this one. Thanks.
your Work-Energy method is excellent ...
but a few chapters ago, F = M g sin (theta)
. . . if you had USED units [kg N/kg] you would have caught your error.
F = M g sin (theta) ?
I'm not sure what you mean. :confused:
you forgot the mass when you calculated the force.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
