Frictionless inclined plane physics homework
A 2.0 kg mass slides down a frictionless inclined plane at a 30-degree angle, starting from rest, and the goal is to determine its speed after sliding 3.0 m. The initial force calculation of 4.9 N was incorrect because the mass was not included in the force equation. The correct force should be calculated using F = mg sin(theta), which results in a different value. The work done on the mass, W = Fd, should also reflect this correction. The final speed calculation must incorporate the accurate force to yield the correct result.
IB
A 2.0 kg mass slides down a frictionless inclined plane that makes an angle of 30 degrees with the horizontal. The sass starts from rest. What is its speed after it has slid a distance of 3.0 m along the incline?
I got:
F = (sin30)(9.8)
F = 4.9 N
W = Fd
W = (4.9) (3) = 14.7 J
W = E_kin
14.7 J = 1/2 mv^2
v = 1.21 m/s
Is my method correct? I'm very unsure how to do this one. Thanks.
your Work-Energy method is excellent ...
but a few chapters ago, F = M g sin (theta)
. . . if you had USED units [kg N/kg] you would have caught your error.
F = M g sin (theta) ?
I'm not sure what you mean. :confused:
you forgot the mass when you calculated the force.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
