Function for y(x,t) wave some questions
  • Thread starter Thread starter yjk91
    Function Wave
The discussion centers on deriving the wave function y(x, t) for a wave traveling along a string with a given velocity and frequency. The initial formula proposed is y(x,t) = Acos(kx - wt), with parameters for amplitude, wave number, and angular frequency calculated based on the wave's properties. The amplitude is confirmed to be 0.003 m, corresponding to the vertical displacement at the origin. Participants emphasize the need to differentiate the wave function to find the velocity at x=0, t=0, and to solve for the amplitude and phase constant. The conversation highlights the importance of understanding wave mechanics in solving such problems.
yjk91
A wave travels along a string in the positive x-direction at 33 m/s. The frequency of the wave is 48 Hz. At x = 0 and t = 0, the wave velocity is 2.8 m/s and the vertical displacement is y = 3 mm. Write the function y(x, t) for the wave. (Use the following as necessary: x and t. Assume x and y are in m, and that t is in s.)
should be the formula
i'm assuming A = 0.003m but it is not so i don't know
w = 2 * pi * f (frequency)
= 2 * pi * 48Hz
= 301.59
k = w / v
= 301.59 / 33(m/s)
= 9.139
so what i have now is y(x,t) = Acos(9.139x - 301.59t + something)
how do i find the amplitude and the missing something if there is one?
thank you
your vertical displacement y(x,t) would be 3mm since at t=0 and x=0 , y=3mm
y(x,t) = Acos( k(0) - w(0)) = A(1) = 3mm = 0.003m
what you have looks right to me. Sorry if its not to clear, it's been a long summer
one example was this question
A wave travels along a string in the positive x-direction at 31 m/s. The frequency of the wave is 47 Hz. At x = 0 and t = 0, the wave velocity is 2.8 m/s and the vertical displacement is y = 3 mm. Write the function y(x, t) for the wave. (Use the following as necessary: x and t. Assume x and y are in m, and that t is in s.)
the answer was 0.0099 * sin(9.53*x - 295.31*t + 2.84)
i know how to get the k and w which was 9.53 and 295.31
but i don't know how to get 0.0099 and 295.31 are
thank you
i know how to get the k and w which are 9.
Find the velocity of the piece of string at x=0, t=0, by taking the time derivative of your function. Then there two equations for the unknown amplitude A and phase constant (something:smile:)
ehild
