Gamma Distribution (Statistics)
kuahji
A random variable X is gamma distributed with a=3, b=2 (alpha/beta). Determine the probability that 1\leqX\leq2
The first thing I did was plug a & b into the gamma distribution formula 1/(b^a \Gammaa * x^(a-1) * e^(-x/b)
Which I ended up with
1/16(x^2 * e^(-x/2)
Which I then though I'd take the integral from 1 to 2
\int 1/16(x^2 * e^(-x/2) dx = 1/16(-2x^2 * e^-.5 - 8x * e^-.5 - 16e^-.5) & then I evaluated that from 1 to 2. Which gave .06...
The answer in the book gives (b-a)^4/80
So where am I going wrong & am I just approaching this problem in totally the wrong way?
Try this for Gamma density.
f(x)= \frac {\beta^\alpha}{\Gamma(\alpha)}x^{\alpha -1} e^{-\beta x}
The books answer would be negative ?
The book answer wouldn't be negative, it'd be ((2-3)^4)/80.
Also tried the formula, it does not work, it gives a probability over 11, which clearly can't be. The only difference between the formula I posted & yours is you have e^-bx & I had e^(-x/b).
I am assuming montoyas7940 looked up the gamma pdf on wikipedia (as I did) and I think that parametrization is correct for your application.
I get:
\int_{1}^{2} 4x^{2}e^{-2x}dx
That doesn't evaluate to 1/80.
Try this maybe: P(1<X<2) = P(X<2)+P(X<1)-1
Oh, I see. I assumed an extra set of parentheses in the books answer. I used the gamma density from "Probability for Risk Management".
Unless I fat fingered a key on my calculator,
is not .6 either.
I read the answer book wrong... sorry. :) Its NOT (b-a)^4/80.
The answer was approx. .0659.
Someone asked about the fact Probability for Risk Management gave a different answer today, but I'm not sure what they eventually decided. Using the formula you give I'm still getting 11.14, but I do recall the professor saying Probability for Risk Managements define their alpha as our beta... what I mean is its flip-flopped from what our notation is in the text we use. Anyway, thanks for your time & the help.
