Gas or liquid which can push piston
The discussion revolves around selecting an appropriate liquid or gas for a lab experiment involving a piston and a manometer. Participants explore the feasibility of using heat, specifically from the sun's radiation, to increase pressure and push the piston.
  • Experimental/applied, Technical explanation
  • One participant inquires about the ideal liquid or gas that can withstand pressure without leaking when heated.
  • Another participant suggests using water as a suitable option for the experiment.
  • A different participant emphasizes the need to use solar radiation to boil the liquid and increase pressure.
  • One participant reiterates the recommendation of water and mentions the use of a concave mirror to focus sunlight for heating.
  • Another participant proposes that air could serve as a "working fluid" for the experiment.
There is no consensus on the best choice of fluid, as participants suggest both water and air, indicating multiple competing views remain.
Participants have not specified the conditions under which the liquids or gases would be used, nor have they addressed potential limitations related to the experiment's setup.
callsunder
Greetings .! This is regarding a lab experiment .I need to find out if we can boil or heat a liquid ,which is connected by with a manometer and a piston .We need to push the piston and also see the reading in the manometer. Which is the ideal liquid or gas , which will not eak or hold on to pressure ?
Chemistry news on Phys.org
Hard to follow, that thing you wrote.
Go for water.
Dear Mr.Borek , we need to use the sun's radiation to boil the liquid .which is the right liquid to raise the temperature of the liquid so that it increases the pressure and pushes the piston
I told you - try with water. You will probably need some way of a concave mirror to focus light. You can make it from cardboard and aluminum oil.
