Gauss' Law: Infinite plane with charge
An infinite plane of charge with a surface charge density of 6.8 µC/m² leads to an electric field calculated as E = 384170.791 N/C. The potential difference of 100 V is used to find the distance between equipotential surfaces using the formula ΔX = ΔV/E, resulting in ΔX = 0.0002603 m. A participant initially miscalculated the conversion to millimeters, stating 2.603 mm instead of the correct 0.2603 mm. The discussion emphasizes the importance of proper unit conversion and significant figures in physics calculations. Ultimately, the correct distance between equipotential surfaces is confirmed to be 0.2603 mm.
SnakeDoc
An infinite plane of charge has surface charge density 6.8 µC/m2. How far apart are the equipotential surfaces whose potentials differ by 100 V? In mm
E=σ/(2ε0)
So first I solved for E= 6.8e-6/(2*8.85e-12) = 384170.791
then because ΔV= E *ΔX
so
ΔX=ΔV/E
so then I substituted
ΔX = 100/ 384170.791
ΔX = .0002603
The site says that I've made a power of ten error the answer must be in mm but I'm not sure what I am doing wrong
ΔX = .0002603
So far you've expressed your ΔX in meters. What value did you enter for your answer in mm? How many significant figures did you provide?
I entered 2.603 mm
SnakeDoc said:
I entered 2.603 mm
Numerically the result looks to be good. How many significant figures do the given data support?
I realized my mistake its supposed to be .2603mm I converted from Meters to millimeters improperly. Thank you.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
