Solving Projectile Motion: Find x and y with Trig. Identities
  • Thread starter Cursed
  • Tags
    General
In summary, the problem is finding x and y using trigonometric identities. The identities used are sin and cos, which are the ratios of opposite and adjacent sides to the hypotenuse. In this case, the problem can be solved by setting up equations using these identities and solving for x and y.
Cursed
39
This isn't a problem, but I need help understanding this so I can do problems.
http://img255.imageshack.us/img255/3479/xythingat6.png
So let's say...
1. This is part of the motion of a projectile
2. You're trying to find x and y
There are trig. identities that will give you x and y.
Example:
x = sin(36)*10
y = cos(36)*10
My question is... Which trig. identity/function do you use to solve for x, and why do you use that identity? Also explain the same thing for y. Please and thank you.
It's the basic defn of sin and cos.
Sin is the ratio of the opposite side over the hypotonuse
Cos is the ratio of the adjacent side over the hypotonuse
If you draw a line down to the X axis from the end of the slope (opposite the 36deg) you have a triangle.
The hypotonuse is 10units, the adjacent side is the distance in x and the opposite side (the exta line you just drew) the opposite side.
And following mgb_phys' instructions you should find x=cos(36)*10 and y=sin(36)*10, the opposite of what you wrote.
[tex]sin x = \frac{opposite}{hypotenuse} [/tex]
[tex]cos x = \frac{adjacent}{hypotenuse} [/tex]
So applying that to your problem:
[tex]sin(36) = \frac{y}{10}[/tex]
[tex]cos(36) = \frac{x}{10}[/tex]
From there it's really straight forward for solving for x and y.
1. How do trigonometric identities help with solving projectile motion problems?
Trigonometric identities allow us to break down a complex problem, such as projectile motion, into simpler components. This makes it easier to analyze and solve the problem using mathematical equations.
2. What is the difference between x and y in projectile motion?
X represents the horizontal distance of the projectile, while y represents the vertical distance. This allows us to track the motion of the projectile in both the x and y directions.
3. How do we use trigonometric identities to find x and y in projectile motion?
We use the trigonometric functions, such as sine, cosine, and tangent, to calculate the x and y components of the projectile's motion. By using the known angle and initial velocity of the projectile, we can apply trigonometric identities to find the x and y values at any given time.
4. Can we use trigonometric identities to solve for other variables in projectile motion?
Yes, trigonometric identities can also be used to solve for other variables such as the initial velocity, angle, or time of flight. This allows us to have a comprehensive understanding of the projectile's motion.
5. Are there any limitations to using trigonometric identities in projectile motion?
Trigonometric identities assume that the projectile is traveling in a vacuum without any external forces, such as air resistance. In real-world scenarios, these assumptions may not hold true, and adjustments may need to be made to the equations to account for these factors.
