General Relativity tensor proof
The discussion focuses on proving that if tauijkl equals 3tauiljk in one coordinate system, it holds true in all coordinate systems. The transformation of tensors is central to this proof, utilizing the similarity transformation T^{x_j} = U^\dagger T^{x_i} U, where U is a unitary tensor. The transformation rule for tensors is applied, demonstrating that the relationship between tauijkl and tauiljk remains consistent across different coordinate systems. By applying the transformation properties, it is concluded that tauijkl=3tauiljk universally. Understanding these tensor properties is essential in the context of general relativity.
regretfuljones
Prove that if tauijkl is a tensor such that, in the {xi}-system, tauijkl=3tauiljk , then tauijkl=3 tauiljkin all coordinate systems.
How would one go about proving this for all coordinate systems?
Remember the similarity transformation of tensors. If I have a tensor that is given in the x_i basis I can find what that tensor looks like in any other basis (say the x_j basis) by the following
T^{x_j} = U^\dagger T^{x_i} U (1)
Here, U is a unitary tensor that relates the components of a vector described in the two different bases. The key property of U is
U^\dagger U = U U^\dagger = I (2)
Here, I is the identity tensor. Anyway, play around with that. You won't need to actually calculate what U is. You just have to know (1) and (2).
The proof of this statement involves understanding the properties of tensors in general relativity and how they transform between different coordinate systems. In general relativity, tensors are mathematical objects that describe the geometric properties of spacetime and they are defined as quantities that transform in a specific way under coordinate transformations.
To prove that tauijkl=3 tauiljkin all coordinate systems, we first need to understand how tensors transform under coordinate transformations. In general, tensors transform according to the following rule:
T^{\alpha\beta\gamma...}_{\mu\nu\rho...} = \frac{\partial x^{\alpha}}{\partial x'^{\mu}} \frac{\partial x^{\beta}}{\partial x'^{\nu}} \frac{\partial x^{\gamma}}{\partial x'^{\rho}}... T'^{\mu\nu\rho...}_{\alpha\beta\gamma...}
Where T and T' represent the tensor in the original and transformed coordinate systems, respectively, and x and x' represent the coordinates in the original and transformed systems, respectively.
Now, let's apply this transformation rule to the given tensor tauijkl, where we have tauijkl=3tauiljk in the {xi}-system. We can write this as:
tauijkl = 3 tauijkl
Using the transformation rule, we can express this in the new coordinate system as:
tauijkl = \frac{\partial x^i}{\partial x'^j} \frac{\partial x^j}{\partial x'^k} \frac{\partial x^k}{\partial x'^l} 3 tauijkl
Since the transformation rule applies to all coordinate systems, this means that the above equation holds true for any coordinate system. Therefore, we can conclude that tauijkl=3tauiljkin all coordinate systems, as desired.
In summary, the proof of this statement relies on understanding the transformation properties of tensors in general relativity and applying the transformation rule to the given tensor. By showing that the equation holds true for any coordinate system, we can conclude that tauijkl=3 tauiljkin all coordinate systems.
