I General Relativity & The Sun: Does it Revolve Around Earth?
JohnNemo
The discussion here
https://www.physicsforums.com/threads/general-relativity-the-sun-revolves-around-the-earth.245334/
concludes that in general relativity there are no privileged reference frames so that, for example, it would be valid to use the Earth as a reference frame and say that distant stars are orbiting the Earth approximately once every 24 hours.
However if distant stars are orbiting the Earth once every 24 hours, would those distant stars not be traveling faster that the speed of light (which is not supposed to be possible)?
No. It would only be true about the coordinate velocities. What you need to compare with is how light would move at the same place as the distant stars.
Likes lekh2003 and Demystifier
JohnNemo said:
The discussion here
In the past - perhaps even these days - sailors would navigate at sea using the position of the stars. They were using the reference frame of the Earth.
In a sense, therefore, this frame has always been valid. The question, however, is how you describe the laws of physics in such a frame. Newton's laws don't hold - the stars accelerate without any force on them. The laws of SR don't hold - the stars have coordinate velocities beyond the speed of light.
It's inevitable, therefore, that if you allow these frames in GR, then the form that the laws of physics take cannot be as simple as they are in SR.
In GR light follows what are called null geodesics and, as you would guess, this implies that light travels (locally) in every inertial reference frame at the invariant speed ##c## and all massive particles travel locally at less than ##c##.
JohnNemo said:
travelling faster that the speed of light (which is not supposed to be possible)?
It's not possible in an inertial reference frame. An inertial reference frame is one where things that feel no forces move in straight lines. But in your rotating reference frame an object that feels no forces will orbit the Earth - moving in a circle. So this is not an inertial reference frame so the speed limit doesn't apply.
This is just an effect of using a complicated reference frame. You will always find that light wins a race with anything else even in this rotating frame. It's just that there isn't a simple relationship between the actual physics and the description of the physics that you picked.
Likes Imager, PeroK and Grinkle
Hello.
In the distant region of the revolving Earth system where $$\rho$$, the radius from the Earth axis, is
\rho>\rho_0=\frac{c}{\omega}=\frac{299792458}{\frac{2\pi}{24*60*60}}[m]=4.122*10^{12}[m],
no physical particles or bodies can stay still in the revolving Earth system.
The invariance of maximum propagation speed, or light speed, applies in local time and coordinate of a frame of reference physical reality of which is proved if there can exist particles or bodies at rest locally in that frame of reference.
So you do not worry about a contradiction you mentioned.
OK. I think I understand that: co-ordinate velocity can exceed c.
So, with that objection disposed of, is it really true that there is no way of telling whether the Earth is spinning, or whether the Earth is fixed and the stars are orbiting it every 24 hours? You can choose whatever reference frame you want and all the laws of physics work OK from whichever reference frame you use?
No. As explained in #4.
OK. How can you tell if you are "really" rotating in absolute terms? What kind of experimental result would establish this?
Well, for the Earth, for example, the Foucault pendulum does a good job.
Likes CalcNerd and nitsuj
You can work in any reference frame you choose. The maths will be hideously complicated if you don't pick a sensible one for the problem at hand.
It depends on your philosophical inclination, basically. You can certainly detect whether or not you are using an inertial reference frame - just let go of something. If it starts to move relative to whatever you regard as stationary and there are no forces (wind, magnetism, whatever) then you're using a non-inertial frame. If it stays stationary then you're in an inertial frame (or your experiment isn't precise enough). For example, lay a pen on your dashboard then drive round a corner or stamp on the accelerator. The pen will start to move relative to the car, from which you can deduce that the car is not an inertial reference. See also hurricanes.
But none of that tells you whether the car is turning or the universe is turning around the car. It seems unlikely that the universe really revolves around me, but I can certainly describe it as doing so. If I just want to think about whether my coffee is going to spill when I take the next corner, "the world is turning around me" might be the smarter viewpoint. If I want to model a black hole a few thousand light years away I'd be daft to pick a me-centered reference frame.
Basically, I don't think there's a clear physical definition of "really" rotating. We can talk about reference frames, and there are certainly different types. But they're pinned to some relevant bit of physics, not necessarily any fundamental reality. Whatever that might mean.
An accelerometer will detect your centripetal acceleration. This works even if you and your lab equipment are sealed up in a windowless room with no input from the outside world.
It gets trickier if you are in a curved spacetime so that there are significant gravitational effects. For example there is no way of detecting that your sealed and windowless room is in orbit around the Earth and changing speed and direction under the influence of the Earth's gravity, instead of moving in a straight line at a constant speed in empty space - it's just freefall either way. What's going on here is that in a curved spacetime there's no single quantity that you can call the "speed" of a distant object relative to you because there is no inertial frame that includes both you and the distant object. The distant object will never move faster than a flash of light that is near it, but depending on my choice of coordinates neither the speed relative to me of that distant object nor of the flash of light will have anything to do with ##c##, the speed of light in a vacuum in my lab.
The Foucault pendulum goes through 360 degrees every 24 hours. As I understand it you are saying that it would only do this if the Earth were rotating in absolute terms (so the fact that it does this proves that it is the Earth which is rotating).
So, in your understanding, if the Earth were stationary and the distant starts were orbiting it every 24 hours, how would you expect the Foucault pendulum to behave then? What difference would you expect to see?
It proves that the Earth is rotating relative to the distant stars.
The same, because the relative rotation is the same.
It does a good job of showing that the Earth rotates relative to the distant stars. But that's still relative rotation, not "absolute rotation".
The best candidate for an indicator of "absolute rotation" is, as @Nugatory said, proper acceleration as measured by an accelerometer. Or, equivalently, you can run an experiment like Newton's bucket--Newton talked about a bucket full of water, and using it to distinguish "absolute rotation" by the shape of the water's surface (flat if not rotating, concave if rotating). But in GR, even this can be considered relative, since which states of the bucket are which is determined by the geometry of spacetime, which is determined by the distribution of stress-energy. So you can consider the bucket's rotation, or lack thereof, as being "relative" to the distribution of stress-energy.
In this context I cannot help but quoting one of the limericks from https://www.physics.harvard.edu/academics/undergrad/limericks
On a merry-go-round in the night,
Coriolis was shaken with fright.
Despite how he walked,
'Twas like he was stalked,
By some fiend always pushing him right.
Likes PeterDonis and ComplexVar89
So does this mean that it is impossible to tell whether the bucket is rotating (in absolute terms)? The behaviour of the water could be due to a rotating bucket. But equally if the bucket were stationary and the starts were orbiting it quickly, the gravitational field thus created would account for the bahaviour of the water.
Given that this is a B level thread, I think that experiments such as Foucault's pendulum is a satisfactory answer.
At an intermediate level you may study rotating reference frames in more detail and derive the Coriolis force or the equation for the precession of Foucault's pendulum.
There is a risk that the more advanced ideas being expounded here cloud what is otherwise a plain matter and confuse you to the point where you cannot learn the basics of physics without digesting more advanced concepts.
That said, you did ask the question. And you did ask about reference frames in GR.
Sorry. My mistake. Would it be in order to re-post my question a an I level thread?
With the meaning you appear to be giving the term "absolute rotation", yes, because there is no such thing as "absolute rotation" with that meaning.
A better way of saying this is that it is the relative rotation of the water and the stars that makes the bucket concave. You can describe this relative rotation in a frame where the bucket is stationary, or a frame where the stars are stationary. Both are valid coordinate charts and can describe the same physical situation.
If you are ok with the discussion being at the "I" level, I can just change the level of this thread to correspond.
Yes. Please.
It's more for you to decide what level of physics you want to understand. I checked your profile and is says "completed undergrad". Was that in physics?
OK so apologies for things going off at a tangent.
Can I restart by asking this question:
Is it really true that there is no way of telling whether the Earth is spinning, or whether the Earth is fixed and the stars are orbiting it every 24 hours? You can choose whatever reference frame you want and all the laws of physics work OK from whichever reference frame you use?
The problem here is not the answer, it's the way you're asking the question. You are assuming that "the Earth is spinning" and "the Earth is fixed and the stars are orbiting it every 24 hours" are two different possible ways the world could be. That's not the case. Both of these verbal descriptions correspond to the same physical situation--the same single way the world is.
Yes, because they are the same laws of physics regardless of which reference frame you use. You can't change the way the world is by changing reference frames. And changing reference frames is all that changes when you switch from "the Earth is spinning" to "the Earth is fixed and the stars are orbiting it every 24 hours". Nothing in the actual world changes; only your description of it does.
Likes JohnNemo
Has the equivalence you describe been generally accepted for, say, the lat 50 years? Has it ever been controversial or been seriously doubted?
As far as GR is concerned, just considering it as a physical theory, the equivalence has always been there and has never been seriously doubted.
However, it's worth noting that there is a long-standing debate over how "Machian" GR is, which often involves examples like the one we are discussing. Some people might misinterpret this as a debate about whether the equivalence really is generally accepted. It's not a debate about that. It's more of a philosophical debate about what different people think a theory "should" look like, and whether GR looks like that, and if not, what a more comprehensive theory that includes GR as a special case within its domain of applicability might look like.
When people first come across relativity, there usually comes a point in the process of understanding where they say "yes, I can see that relative velocity (say) depends on the observer, but what is really happening, what is the real velocity?" And it takes a further leap to understand that not only is the answer unknown but that it is believed that the entity envisaged (absolute velocity) does not correspond to any physical reality.
I can conceive of two different types of possible more comprehensive theory
1. A theory shows that GR is wrong in certain circumstances within its own claimed domain of applicability. An example of this from the past would be Newton's theories - incorrect for high velocities (albeit still a very useful approximation for everyday practical purposes).
2. A theory which shows that there are objective reasons for preferring the view of one observer to another (not just for some immediate practical purpose but for objective reasons which might be expected to gain universal acceptance). An example of this might be the discovery of cosmic background radiation. I believe that some people at the time thought of this as bringing back the idea of absolute motion because it was possible to measure velocity relative to the background radiation and because the radiation was produced by the big bang (which was also presumed to be responsible for the laws of physics as we understand them) there was something special about it which might justify its use as the "standard" universal reference point for measuring absolute velocity. I think this suggestion did not gain much traction because cosmic radiation, like everything else, is affected by gravitation (and so is not fixed and uniform in the same way as the ether was envisaged as being) but this is just an example of a kind of theory which would not mean that GR was wrong but would mean that there were objective reasons for preferring one point of reference (or one class of points of reference) to another as some kind of standard.
Is the kind of comprehensive theory you mention 1, or 2, or something else?
Not 1, because GR has very good experimental confirmation within its domain of applicability. So any more comprehensive theory would have to make the same predictions that GR does within that domain.
Not 2 as you state it, because the presence of something like the CMBR, which picks out a particular state of motion (the state in which the CMBR looks isotropic), does not mean there is "absolute motion" or an "absolute frame". It just means the stress-energy content of the universe has a particular configuration, and the laws of GR specifically relate the geometry of spacetime to the actual configuration of stress-energy, so different configurations of stress-energy lead to different spacetime geometries. That doesn't change any of the laws of physics, it just changes the particular solution of those laws that describes what you're interested in.
So the only option left is "something else", but it's not really possible to describe what that something else is, because if we knew that, we would already have the more comprehensive theory. The only thing we think we know about it is that it will be some kind of quantum theory of gravity (although even that is not universally believed; Freeman Dyson, for example, has speculated that maybe gravity simply isn't quantized, so the best we will be able to do is figure out how to have classical gravity--GR--coexist with quantum field theory for everything else).
Likes ComplexVar89
From the Earth's reference frame, what accounts for the stars orbiting the Earth? I'm assuming that the Earth's gravity has a negligible effect on distant stars. Is it some kind of frame dragging effect which makes the stars circle the Earth?
  • #31
The Coriolis force. Note that the Coriolis force actually gives you twice the force that would be required, but half of that is countered by the centrifugal force.
  • #32
Sorry, my question was badly worded. By using the word "accounts" it sounded like I was asking a question about how Newtonian mechanics accounts for it by using fictitious forces.
What I meant to ask was: "In GR what is the cause (explanation) of the circular rotation of the stars"
  • #33
In one sense nothing needs to account for it. If you bounce up and down on a trampoline you could ask what accounts for everyone else bouncing down and up in your frame?
Whatever it is it's not the trampolinist's gravity!
Note that there are other rotating planets, with different angular velocity from the Earth. So, what forces are the distant stars supposed to feel?
And someone living on a distant planet will have no way to measure the effect of the Earth's rotation on them. Because there is none.
This is where is trying to grasp the I or A level answer you lose touch with the B level answer.
  • #34
In GR the equations of motion come from the differential description of spacetime. In one reference frame the line element has a certain form, which leads to the geodesic equations, which leads to a solution for a particle or light ray in those coordinates.
If we change coordinates, we change the form of the line element, hence the geodesic equations hence get a different solution in those coordinates.
But, unless the maths has gone wrong, the two coordinate solutions must describe the same physical solution.
There is no cause in one frame or the other except that particles are following the natural paths through spacetime. Only the coordinate description of that spacetime and the associated geodesics changes.
  • #35
There is none. Causes don't change when you change frames, and something that doesn't even exist in one frame can't have a cause in another frame.
What you should be asking is, what is the cause of the relative rotation of the Earth and the distant stars. And the answer to that is the simple mundane answer: the geometry of spacetime and the worldlines of the matter inside the Earth and of the distant stars within that geometry. A further answer would go into the history of how those various pieces of matter came to have those worldlines, and how the spacetime of the universe and in the particular regions in question came to have its geometry.
  • #36
This seems to have taken a meandering trip to somewhere other than enlightenment.
Consider a coordinate system centered on New York. In this coordinate system, an object has a certain set of coordinates describing its position. Now consider a coordinate system centered on Los Angeles. In this coordinate system, the same object has a different set of coordinates describing its position. When switching coordinates, did the object move?
That's the same thing happening here.
  • #37
I think I was wrong to use the word "cause" in my question. I should have stuck to the word "explanation".
Explanations comes in all shapes and sizes and some are more helpful in some situations than others. And it does seem to me that some explanations can be more or less reference-frame specific in that their explanatory power may be greater in one frame and less (or nil) in another.
For example if I leave my arms loose and spin round very fast, my arms will stretch out horrizontally. A typical explanation of why this is would be to say that because I am rotating (relative to the Earth's reference frame) my arms are accelerating towards my body and that is why they stretch out.
Now if we consider my own reference frame, clearly this explanation has no explanatory power since in my own reference frame I am not rotating. So we might look for another explanation for what is happening in this reference frame. One explanation I have heard is that the distant stars spinning round me create a gravitational field which pulls my arms out. I would be interested to know what you think of this explanation but the main point for present purposes is that some explanations work better than others in particular reference frames. This does not mean that every single reference frame has its own unique explanation, and there may be some explanations which are useful over many, perhaps all, reference frames, but at least some types of explanation are more useful in some reference frames than others. So it seems to me that it is not wrong to ask if there is an explanation in the context of a particular reference frame. Of course the answer to any specific question of this nature may be "sorry- I can't think of one (other than a very general mathematical explanation applicable to all reference frames)". But it seems to me that it is not wrong to ask.
To develop this point a little more: it seems to me that the very idea of equivalence necessarily assumes that some explanations are more natural and useful in some reference frames rather than others. 100 years ago we discovered that gravitation and acceleration were equivalent, but we didn't ditch the word "acceleration" and just use the word "gravity" from then on. We continued to use the word "gravity" for those situations and reference frames for which it appeared to be the most useful word to use, and continued to use "acceleration" where that appeared more natural, always remembering, that they were equivalent in the sense of ultimately referring to the same underlying reality.
So my intention when asking the question was not to suggest that reality could be different for different frames of reference, but simply to ask if there was some useful explanation (beyond the very general) which could be given for the phenomenon of stars orbiting the Earth (in the Earth's frame of reference). If there isn't, fair enough, but I wanted to make clear what I was intending to ask.
  • #38
  • #39
PeroK said:
@JohnNemo post #34 didn't help?
Nothing wrong with what you said but a bit general. My fault for using the word "cause" which was ambiguous.
  • #40
What level of physics do you understand? If I said light follows null geodesics, where ##ds^2 = 0##, do you understand what that means?
  • #41
IMO this doesn't make a difference, because a valid explanation has to be made in terms of valid causal factors. More precisely, a valid explanation of an actual physical phenomenon, as opposed to an artifact of your choice of coordinates, needs to be made in terms of valid causal factors.
Consider @Vanadium 50 's example of an object whose coordinates change when you change from a New York-centered coordinate chart to a Los Angeles-centered coordinate chart. As far as physics is concerned, there is nothing to "explain" because nothing happened. If you ask why the object's coordinates changed, the answer won't involve any kind of physical cause; the answer will be "because you changed your coordinates". Whereas, if the object collides with another object and gets damaged, any explanation of why the object got damaged will have to be in terms of the collision and its parameters, which don't change when you change coordinates.
I don't agree with this either, for the reason just given: valid causal factors don't change when you change frames.
I don't know if this kind of explanation is "typical", since you haven't given any references, but a correct explanation of why this is would be to say that there are two causal factors acting on your arms: their inertia, and the forces exerted on them by the rest of your body. What happens to your arms is determined by the combined effect of these two causal factors. These causal factors are the same no matter which frame you choose.
And this explanation can work, if you realize that the term "gravitational field" (like the term "Coriolis force", which came up in an earlier post in this thread) is really a way of referring to the "inertia" causal factor--or, if you want to put it in more GR-like terminology, the "geometry of spacetime" causal factor. But notice that this causal factor alone does not explain what actually happens to your arms: if this causal factor were the only one operating, your arms would fly away and not stay attached to your body. So to explain what actually happens to your arms, you need both causal factors I mentioned: inertia/spacetime geometry, plus the internal forces between your arms and the rest of your body. Only the combination of the two explains what actually happens to your arms.
Part of the confusion here is that our ordinary language is not relativistic, in the sense that it gives different names to the same causal factor when viewed from different frames. In the frame in which the distant stars are at rest and the person is rotating, the "spacetime geometry" causal factor is usually called "inertia", whereas in the frame in which the person is at rest and the distant stars are rotating, the same causal factor is called "gravitational field" or "Coriolis force" (combined with "centrifugal force"). The different language makes it appear that it's a different causal factor, when in fact it's the same one.
No, it's the opposite: it's the idea that those different words used in different frames are just different names for the same explanation--the same causal factor--not different explanations.
Likes PeroK
  • #42
Can you elaborate on the "longstanding debate over how 'Machian' GR is"?
I thought that Mach's Principle was the very idea of equivalence which you have said is an uncontroversial part of GR, but I must be missing something and it can't be that simple if there is such a longstanding debate.
  • #43
The short answer is that it's a disagreement over whether and to what extent your very next sentence...
...is true.
  • #44
...is true.
Is the area of debate concentrated upon rotating frames?
  • #45
That seems to be the scenario that is most frequently used as an example in the debate, probably because ordinary experience shows us that rotation works differently from linear motion. It's fairly easy to grasp that linear motion is relative because we don't feel any force due to linear motion. It's much harder to grasp that rotation is relative because we feel a force due to rotation. The obvious intuitive explanation of that force is that rotation is "absolute" in a way that linear motion is not.
  • #46
Can I ask a question which I thought I had asked before but which I now see I had asked before in more restrictive terms than I had intended:
Has the truth of the equivalence principle in GR been seriously doubted in, say, the last 50 years? By 'truth' I mean correspondence between what GR predicts and reality (so far as we are able to measure it).
  • #47
No. The debate I referred to about how "Machian" GR is is not a debate about whether the EP is true. And btw, it's not just "true in GR", i.e., it's not just theoretical; it's been tested to very high accuracy. The Wikipedia page gives a decent overview of the experiments that have been done:
https://en.wikipedia.org/wiki/Equivalence_principle
  • #48
In the Middle Ages before Copernicus it was generally believed that the Earth was fixed immovable at the centre of the universe, and it was everything other than the Earth which was moving. Copernicus proposed that the Sun was fixed immovable at the centre of the universe, and it was everything other than the Sun which was moving. And Copernicus' view gained wide acceptance for the next couple of centuries until people worked out that if there was a centre of the universe it definitely was not either the Sun or the Moon.
In popular histories of science it is often said that Copernicus was 'right' and you sometimes get the impression that even some scientists today feel that Copernicus was 'more right' than his predecessors, but from what you say about equivalence it seems that there is no basis for thinking that Copernicus was 'more right' that his predecessors.
Formally both Copernicus and his predecessors were wrong because nothing is 'absolutely' at rest - the concept having to meaning. And even if we are kind to them and overlook that and take them to be referring to relative motion, then they would both the equally right. So neither 'more right' than the other.
  • #49
Copernicus's ideas were a major advancement in scientific thinking. To conceive that the Earth might be moving round the Sun was a significant step.
Moreover, in finding a model for the relative motion within the solar system it was a critical breakthrough. The elliptic orbits could only be found by looking at the solar system as heliocentric.
Copernicus took the right step, as did Galileo and Newton. You can't judge the progress of science by a simple test or whether someone was completely right or not.
  • #50
JohnNemo said:
...So neither 'more right' than the other.
I should get a share of the revenues, I've posted this link so often... http://chem.tufts.edu/AnswersInScience/RelativityofWrong.htm
I mentioned in your other thread that the popular conception that modern physics has somehow proved classical mechanics wrong is itself wrong. That's true, and more generally most laypeople do not understand the extent to which science advances by extension and improvement rather than wholesale replacement.
Likes Vanadium 50, PeroK, PeterDonis and 1 other person
