Generating Function for Lagrangian Invariant System
4 replies · 2K views
Physgeek64
Given a system with a Lagrangian ##L(q,\dot{q})## and Hamiltonian ##H=H(q,p)## and that the Lagrangian is invariant under the transformation ##q \rightarrow q+ K(q) ## find the generating function, G.
##\delta q = \{ q,G \} = \frac{\partial G}{\partial p} ##
##\delta p = \{ p, G \} = -\frac{\partial G}{\partial q} ##
in this case ##\delta q =K(q)##
Hence
##G= pK + c_1(q) ##
Assuming the Lagrangian is of the form ##L=\frac{1}{2} m q^2 -V(q)##
then ##p=m\dot{q}##
and ##\delta p = m\dot{K} = mK' \dot{q}= pK'##
##\delta p = pK'=-\frac{\partial G}{\partial q} ##
## G= -pK +c_2(p)##
I know this is not right because i have two different expressions that can't be matched, but i can't think of another way to do this.
Many thanks
What makes you think you can assume this?
Edit: Also note that { and } are LaTeX delimiters used for grouping. To actually get the brackets of the Poisson bracket you need to use \{ and \}.
Ahh okay then, so I guess i can't make that assumption. In which case i don't know how to proceed, any tips?
Thank you, i will change them :)
Consider how the canonical momentum ##P = \partial L/\partial \dot Q## connected to ##Q = q + K(q)## must change relative to ##p##. This should give you ##\delta p##.
## \frac{\partial L}{\partial \dot{Q}} = \frac{\partial L}{\partial \dot{q}} \frac{\partial \dot{q}}{\partial \dot{Q}} =\frac{\partial L}{\partial \dot{q}} \frac{1}{1+\dot{K}'} = p \frac{1}{1+\dot{K}'} ##
?? is this along the right lines?
Many thanks
