Geometry Help: Solving Lagrangian Problem
  • Thread starter Thread starter Xyius
    Geometry
The discussion focuses on solving a geometry-related issue within a Lagrangian mechanics context, specifically regarding the relations for x and y in a problem involving a cube rolling on a sphere. The user expresses confusion about deriving the formula for y, which includes terms like (r+b)cos(θ) and rθsin(θ). Clarifications are made about the assumptions regarding the cube's initial position and the implications of rolling without slipping. Ultimately, the user gains understanding and thanks the contributors for their help. The conversation highlights the importance of clear assumptions in geometric problems related to physics.
Xyius
This is a Lagrangian problem, I am posting it here in introductory physics because what I need help with isn't in Lagrangian mechanics, but rather geometry.
http://img97.imageshack.us/img97/7504/what3.png
I am confused as how they got those relations for x and y. I have tried to make sense out of it but cannot figure it out. I am sure it is something really simple!
Let's start with y. You can probably understand where the (r+b)cos(θ) comes from I hope. Now imagine that you roll the cube around the sphere by an angle θ. The length of the line CB is then what? That's right! It's rθ. So obviously this adds a height rθsin(θ). Now you have
y = (r+b)cos(θ) + rθsin(θ)
Hm. I agree with Xyius; I don't think that, as stated, the formula necessarily holds. Consider a much smaller cube in the same place, at the same angle.
The unstated assumption is that the cube was originally placed square and centered on top of the cylinder and rolled to its current location, but that hasn't been specified.
A much smaller cube would not be able to get to as large of an angle, because the cube must roll without slipping. The formula is valid.
Ah! I understand now! Thank you very much :]
