Getting graph of v(t) on oscilloscope?
To display a v(t) graph on a Tektronix TDS 210 oscilloscope, ensure the voltage input is under ten volts AC to avoid damage. Properly trigger the signal either internally or externally and adjust the time base according to the frequency of the waveform; for a 100 MHz signal, set the time resolution to 1 to 10 nanoseconds per sweep. If the time base is set incorrectly, the waveform may not be visible. Tutorials from Tektronix can provide additional guidance on using oscilloscopes effectively. Accessing the manual can also be beneficial for specific instructions.
seto6
how do i display a v(t) graph of a oscilloscope.
i don't have a manual for it.
Here are some good primers and tutorials from Tektronix on oscilloscopes:
http://www.tek.com/learning/oscilloscopes/
Which 'scope are you working with?
its a Tektronix model TDS 210
When you say 'graph', do you mean like a stored image on the scope of a waveform? Like in digital storage scopes? Or do you mean just voltage display? I assume you are looking at some AC waveform, do you know the frequency? There is usually a BNC or two where you input the voltage, usually under ten volts AC, high voltages can damage the scope. Then you have to trigger the signal, either internally or externally and you have to have the right time base dialed in. If you are trying to display a frequency of 100 Mhz, you would need to have the time resolution at somewhere around 1 to 10 nanoseconds per sweep. If you tried to look at 100 mhz and had 1 millisecond dialed in you would just see a band of light with no signal resolved. Hope that helps.
Don, AI3N, Delaware Lehigh Amateur Radio Club, Allentown/Bethleham Pa.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
