Getting the identity of an unknown element in a reaction.
The discussion revolves around identifying element X in the reaction XCl2 + Cl2 → XCl4, given the masses of the reactants and products. The user initially struggles with determining the mass percent composition and calculating the moles of chlorine gas, which weighs 71 grams/mol. A suggestion is made to calculate the moles of Cl2 from its mass, leading to the conclusion that the reaction proceeds with no excess reagents, indicated by the conservation of mass. The user is guided to find the realistic mole value of chlorine and subsequently determine the molar mass of element X by subtracting the mass contribution of chlorine from the total mass of XCl2. Ultimately, the user successfully finds the identity of element X.
philistinesin
Hi.
I'm having a hard time solving this problem.
I have to find the identity of element X in the following reaction:
XCl_2~+~Cl_2~-->~XCl_4
knowing that 10 grams of XCl_2 + 2.55 grams of Cl_2 produces 12.55 grams of XCl_4.
Now, I thought about doing mass percent composition that way I could know how much Cl there was in relation to the element X but I don't know any way to do that.
I'm stuck. Any ideas?
Chemistry news on Phys.org
You may try starting with the mole calculation of chlorine; it is 71 grams/mol. How many moles are there in 2.55 grams of chlorine gas, if one mole weighs 71 grams?
If we assume that all of this chlorine gas is reacted, then you will find how many moles of the unknown chloride along with the formed new chloride, and easily find the molar mass of X from there.
Note that if there is a deviation in calculating X in the first and second chloride, you may have to consider that the reaction did not proceed 100%.
The reaction is in stoichiometric equivalence, the way you can tell is due to exact mass conservation: 2.55 + 10 = 12.55, thus there is no excess reagent.
Since all of the reactants and products are in the same mole to mole ratio, you can start with finding the realistic mole value of chlorine, this will be the realistic mole value of X.
The realistic value of X can be found simply by subtracting (2.55x 2...you should know why) from 10. Now you should easily be able to find the molar mass.
Thanks to all for the help.
I got the answer. :cool:
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
