Given a force equation and mass, find velocity
2 replies · 3K views · last reply
gwhite00
The force on a particle of mass 3.0 kg moving in one dimension at time t, is given by:
F = 9.0 +2.0t - 4.0t2. What is the velocity of the particle? (Let v0=0 and ti=0)
[/B]
I know to use F = ma for sure.
And I believe this is the motion equation I should be using, but I'm not completely sure: v = v0 + at
[/B]
I substituted in the given equation for F and the given mass into Newton's 2nd Law equation and solved for the acceleration.
I then further substituted in acceleration into the velocity equation and let v0 = 0 and t = 0, which just appeared to make the velocity 0 m/s which doesn't seem correct.
Could someone point me in the correct direction?
Hi gwhite00. I see you are new here. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
F= ma
can give you the acceleration vs time graph, then use integral calculus.
Acceleration is not constant.
Thanks NascentOxygen for your quick reply.
While I do know how to use integral calculus being in Calculus III, we are not actually using it in our class. So far my professor has only touched on derivational calculus.
I know from previous problem sets written by this professor that his calculus based problems don't even up with a integer answer so I know that t will be part of my result.
I'm just not sure if I'm using the correct equation of motion to achieve an answer of a velocity equation at time t as an answer.
