Global Coord Atlas Universe: GR Coord Charts, Speed Light
In summary, the size and content of local coordinate charts in General Relativity atlases depends on the curvature and sensitivity of the charts, and the speed of light is always defined in terms of the angle between two worldlines.
berra
I am wondering how big the local coordinate charts in a coordinate atlas of General Relativity can be. Is it just a few nanometres or all the way to the furthest stars? Also I wonder how the speed of light is defined in GR. Is the velocity defined as the differential with respect to coordinate time? Is the coordinate time only defined with respect to an observer, so a coordinate time is always (a diffeomorphism away from) a proper time?
Because of GR we are careful to measure the speed of light (for the purposes of Einstein's postulate) in a local spacetime which is flat ... since the laws of physics must be locally consistent.
I take it you are talking about an "atlas" in the topological sense.
You seem to be asking: how much of space-time do you need to describe in order to get it all?
To quote Deep Thought: "Hmmmm... tricky..."
I don't think anyone knows.
I found a starting point discussion here:
http://physics.stackexchange.com/qu...-about-the-topological-structure-of-spacetime
... starting point only, use the discussion to guide your further inquiries.
I did find: http://at.yorku.ca/t/a/i/c/28.htm
But you may have noticed that everyone talks about things being a certain way "locally" and you are wondering how big "locally" actually is... and that "depends". On the local space-time and how you want to organize the charts. Consider the question by analogy with constructing charts for an atlas of the Earth's surface.
This depends on the characteristic curvature scales of space-time.
No it's the change in spatial distance divided by the change in time at a given event on an observer's world-line as measured using the observer's ideal rulers and ideal clock.
It's the other way around. Coordinate time is always a diffeomorphism away from proper time relative to some observer so it can be defined as the time read by a non-ideal clock carried by an observer (non-ideal meaning the observer has readjusted his clock rate so as to read the coordinate time instead of the proper time).
This depends on the curvature and the sensitivity. A local chart is the same as an inertial chart to first order, however the curvature causes deviations from flatness to second order. How big depends on how quickly those second-order effects pile up and how sensitive your experiment is to them.
Many coordinate charts do not even have a coordinate time. The geometrical way to understand speed is that it is a function of the "angle" between two worldlines where at least one of the worldlines is timelike. This avoids any confusion about coordinate charts, and using that definition the speed of light is always c wrt any timelike worldline.
Thank you for your questions regarding the coordinate atlas of General Relativity (GR) and the speed of light. I can provide some insights and clarifications on these topics.
Firstly, the size of local coordinate charts in a coordinate atlas of GR can vary greatly depending on the specific system or phenomenon being studied. In general, the size of the charts can range from nanometers to astronomical scales. This is due to the fact that GR is a theory of gravity, and as such, it can describe the behavior of objects and phenomena at both small and large scales.
To give some examples, in the context of black holes, the size of the local coordinate charts can be very small, on the order of nanometers, as it describes the behavior of spacetime near the event horizon. On the other hand, when studying the expansion of the universe, the size of the charts can be very large, on the order of billions of light-years, as it describes the behavior of spacetime on a cosmological scale.
Moving on to your question about the speed of light in GR, it is defined as a fundamental constant in the theory and is denoted by the symbol c. This constant represents the maximum speed at which any object or information can travel in the universe. It is important to note that the speed of light in GR is not dependent on the choice of coordinates, but rather it is a universal constant that is the same for all observers.
As for the definition of velocity in GR, it is indeed defined as the differential with respect to coordinate time. However, it is important to note that coordinate time is not the same as proper time. Coordinate time is defined with respect to an observer's reference frame, while proper time is the time measured by a clock that is at rest in that reference frame. So, while coordinate time can vary for different observers, proper time remains the same.
In summary, the size of local coordinate charts in a coordinate atlas of GR can vary greatly, and the speed of light is a fundamental constant in the theory that is the same for all observers. Velocity is defined as the differential with respect to coordinate time, but it is important to distinguish it from proper time. I hope this helps clarify your questions.
Related to Global Coord Atlas Universe: GR Coord Charts, Speed Light
What is the Global Coord Atlas Universe?
The Global Coord Atlas Universe is a comprehensive map and chart system that displays coordinates and coordinates-related information for different celestial bodies, such as planets, stars, and galaxies.
What is GR Coord Charts?
GR Coord Charts refers to the use of General Relativity (GR) to create coordinate systems and charts for objects in the universe. This allows for a better understanding of the structure and movement of celestial bodies.
How is the Speed of Light related to the Global Coord Atlas Universe?
The Speed of Light is a fundamental constant in physics that is used to measure distances and time in the universe. In the Global Coord Atlas Universe, the Speed of Light is used to calculate the coordinates and distances of celestial bodies.
Who uses the Global Coord Atlas Universe?
The Global Coord Atlas Universe is mainly used by scientists, astronomers, and astrophysicists to study and understand the universe. It can also be used by students and enthusiasts to explore and learn about celestial bodies.
What are the benefits of using the Global Coord Atlas Universe?
The Global Coord Atlas Universe allows for a more accurate and comprehensive representation of the universe, which can aid in scientific research and understanding. It also provides a standardized system for mapping and locating celestial bodies, making it easier to communicate and collaborate among scientists.
