How High Is a Meteor When It Accelerates Toward Earth?
The discussion revolves around calculating the height of a meteor above Earth's surface based on its acceleration and mass. A 12 kg meteor experiences an acceleration of 7.2 m/s², prompting questions about the gravitational force and the relevant equations. Participants clarify that the gravitational force equation, Fg = Gm1m2/r², should be correctly manipulated to find the height, r, and that m1 is Earth's mass while m2 is the meteor's mass. There is confusion about the variables, particularly in equating acceleration with gravitational force, but it is confirmed that the meteor's mass cancels out in the calculations. The conversation emphasizes the importance of correctly applying Newton's law of universal gravitation to solve the problem.
EE123
A 12 kg meteor experiences an acceleration of 7.2 m/s^2, when falling towards the earth.
a.) How high above the Earth's surface is the meteor?
b.) What force will a 30 kg meteor experience at the same altitude?
Fg = ma , Fg =Gm1m2 / r^2
a = Fg / m, thus:
Fg / m = Gm1m2 / r^2
then:
r = √ (Fg / Gm1m2(m))
I got this far, somewhat understanding what I was doing the equation manupulation. Please help me! I searched this question up, but that thread was not helpful.
I don't know how to solve the question. The altitude is the radius from the earth? and since a = Fg / m, :S I equated this with the Fg = Gm1m2 / r^2, :|.
Please help!
a = Fg / m, thus:
then:
Do you understand what "Gm1m2/r^2" means? What is G? What are m1 and m2?
A really major error is setting "a= Fg/m= Gm1m2/r^2". "Gm1m2/r^2" is the force due to gravity, not the acceleration. What you want is Fg= ma= Gm1m2/r^2.
Now, again, what are m1 and m2?
That wolyld be correct but you didn't! You equated it to a, not Fg.
Please help!
Yes I do understand what the equation: Fg = Gm1m2 / r^2 this is what my notes say (taking an online physics course, they provide notes)
G = gravitational field constant, m1 and m2 are the two masses, Fg = the force of gravity acting on each object,
r = the distance between the centres of the two masses.
this is the Newtons law of universal gravitation in the above equation form.
So ma = Gm1m2 / r^2 ??
which means r = √ (ma / Gm1m2)?
m1 would be the Earth's mass and m2 would be the meteor mass? but the mass, m2, would cancel out right?
It looks as if you have three different masses, m1, m2 and m. There are only two objects, so there should only be two different masses.
EE123 said:
ma = Gm1m2 / r^2 ??
The top equation is right, but you solved for r wrong.
And you are right about m2, it does cancel.
