Meteor Gravitational Field Question
A 12 kg meteor falling towards Earth experiences an acceleration of 7.2 m/s², leading to a calculated altitude of approximately 1.06 x 10^6 m above the Earth's surface. The confusion arises regarding whether to use gravitational force (Fg) or the acceleration (a) in calculations for the radius (r). The user questions if they should divide by Fg or a when applying the gravitational equation. For part b, the force experienced by a 30 kg meteor at the same altitude is correctly calculated as 216 N. Overall, the discussion highlights the complexities of gravitational calculations and the importance of using the correct parameters.
Ess_Elle
A 12 kg meteor experiences an acceleration of 7.2 m/s^2 when falling towards the earth.
a) How high above the Earth's surface is the meteor?
b) What force will a 30 kg meteor experience at the same altitude?
F
g= Gm1m2/r2 m1m2
r2 = Gm1m2/Fg
r = √Gm1m2/Fg
Please help, I have been stuck on this question for hours trying to figure out if what I am doing is right. I am really confused right now, but here is my attempt at the solution:
Fg= Gm1m2/r2 m1m2
r2 = Gm1m2/Fg
r = √Gm1m2/Fg
r = √(6.67x10^11)(5.98x10^24)/7.2 m/s
r = 7442987.005 = 7.44 x 106 m
Paraphrase: The altitude above the earth’s surface is 7.44 x 106 m - 6.38 x 106 m = 1060000 = 1.06 x 106 m.
Now, I am confused because in an example in my lesson, they divide the entire sq. root equation by the force of gravity found, rather than by acceleration (which in this case is 7.2 m/s). I am unsure if I am supposed to divide by Fg rather than a? See below what I mean:
Fg = mg
Fg = (12 kg)(9.8 N/kg)
Fg = 117.6 = 118 N
which would make the equation, r = sq.rt| (6.67 x10^-11)(5.98x10^24)/118 N?
This again confuses me even more, because in this question, I think that Fg = ma = Gm1m2/r^2. So maybe if I am to be dividing by force of gravity, that means, rather than multiplying mg, I would have to multiply ma? See below:
Fg = ma
Fg = (12 kg)(7.2 m/s)
Fg = 86.4 N
If the above equation is correct, then would I have to divide r = sq.rt| (6.67 x10^-11)(5.98x10^24)/86.4 N?
Please help, I am so confused! Am I somewhat on the right track? :/
Oh, I forgot to post my solution to part b). I think I have done part b) correctly. See below:
F = ma
F = (30 kg)(7.2 m/s)
F = 216 N
Paraphrase: Therefore, a 30 kg meteor at the same altitude will experience a force of 216 N.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
