Gravity force on Jupiter problem
The discussion focuses on calculating the mass and weight of a watermelon on Jupiter's moon Io, given its weight on Earth. The weight of the watermelon on Earth is 49.0N, and the acceleration due to gravity on Io is 1.81m/s^2. The mass of the watermelon is determined to be 4.99 kg on Earth, which remains constant regardless of location. To find its weight on Io, the formula F = m * a is applied, leading to confusion about the calculations. Ultimately, it is clarified that while weight changes with gravity, mass remains the same across different celestial bodies.
Whatupdoc
At the surface of Jupiter's moon Io, the acceleration due to gravity is 1.81m/s^2 . A watermelon has a weight of 49.0N at the surface of the earth. In this problem, use 9.81m/s^2 for the acceleration due to gravity on earth
1.) What is its mass on the surface of Io?
2.) What is its weight on the surface of Io?
working on #1, F=m*a
F = m * 1.81
all we really know is (a) of Io. but we do know the force(49.0N) of earth, how would i convert that to the forces of Io?
Your mass, my mass, mass of object x, etc. is going to be the same whether you're on the Earth, the moon, Io, etc. It is the weight that changes depending on your location's acceleration due to gravity.
As it stands you have enough info to solve for the mass of the watermelon on Earth...
yes, but I am not trying to solve for the mass of the watermelon on earth, that was another question, but i already got the answer. it's 4.99 kg
im trying to solve for the mass on the surface of Io. here's what i done:
F= m*a
49 = m*1.81
m = 27.07kg
that's the mass of Io that i got, but it's the wrong answer.
And what I'm telling you is the mass of the watermelon doesn't change because it is now on Io. The weight changes because the acceleration due to gravity changes, the mass remains the same.
oops, my bad, i thought you said that the weight doesn't change. i misread your post
No problem, it happens :)
