Explore Binary System Inspiral w/ 1.5 Solar Masses
In summary: I'm not sure either, but I think the gravitational waves must be carrying away angular momentum as well as energy. As the two stars spiral inward, the net angular momentum is decreasing. For two equal mass stars, I think the total angular momentum is proportional to sqrt(G*m^3*r). Where else can the angular momentum go except to be carried away by the gravitational waves? I'm not familiar with the derivation in MTW, but I expect that it will be similar to the quadrupole formula for gravitational radiation from an isolated system, where the radiation is ultimately powered by the changing quadrupole moment of the system.
wolram
Dearly Missed
4,446
558
From Wiki.
The pulsar and its neutron star companion both follow elliptical orbits around their common center of mass. The period of the orbital motion is 7.75 hours, and the two neutron stars are believed to be nearly equal in mass, about 1.4 solar masses. Radio emissions have been detected from only one of the two neutron stars.
The minimum separation at periastron is about 1.1 solar radii; the maximum separation at apastron is 4.8 solar radii. The orbit is inclined at about 45 degrees with respect to the plane of the sky. The orientation of periastron changes by about 4.2 degrees per year in direction of the orbital motion (relativistic precession of periastron). In January 1975, it was oriented so that periastron occurred perpendicular to the line of sight from Earth.[2] [5]
The orbit has decayed since the binary system was initially discovered, in precise agreement with the loss of energy due to gravitational waves predicted by Einstein's general theory of relativity.[2][5][6][7] The ratio of observed to predicted rate of orbital decay to be 0.997±0.002.[7] The total power of the gravitational radiation (waves) emitted by this system presently, is calculated to be 7.35 × 1024 watts. For comparison, this is 1.9% of the power radiated in light by our own Sun. (Another comparison is that our own Solar System radiates only about 5000 watts in gravitational waves, due to the much larger distances and orbit times, particularly between the Sun and Jupiter).
With this comparatively large energy loss due to gravitational radiation, the rate of decrease of orbital period is 76.5 microseconds per year, the rate of decrease of semimajor axis is 3.5 meters per year, and the calculated lifetime to final inspiral is 300,000,000 years.[2] [7]
Mass of companion: 1.387 MSun
Orbital period: –7.751939106 hr
Eccentricity: –0.617131
Semimajor axis: 1,950,100 km
Periastron separation: 746,600 km
Apastron separation: 3,153,600 km
Orbital velocity of stars at periastron (relative to center of mass): 450 km/s
Orbital velocity of stars at apastron (relative to center of mass): 110 km/s
In 2004, Taylor and Joel M. Weisberg published a new analysis of the experimental data to date, concluding that the 0.2% disparity between the data and the predicted results is due to poorly known galactic constants, and that tighter bounds will be difficult to attain with current knowledge of these figures. They also mapped the pulsar's two-dimensional beam structure using the fact that the system's precession leads to varying pulse shapes. They found that the beam shape is latitudinally elongated, and pinched longitudinally near the centre, leading to an overall figure-of-eight shape.[3]
From this i am trying to understand what is being converted into gravity waves, is it angular momentum, mass, or what.
In a binary system how would one calculate which one would inspiral into the other.
And how many watts per year for say a binary system of 1.5 solar masses each would be given off before coalition. given some arbitrary orbit.
Space news on Phys.org
Misner,Thorne, and Wheeler (MTW) have a good derivation of the generation of gravitational waves by binary stars in chapter 36. For circular orbits, the power radiated in GW is given by:
L(GW) = 32/5 μ^2 M^3 / a^5 where μ= m1*m2/(m1+m2) , M = m1+m2, and a is the radius of the orbit.
For an elliptical obit, this gets multiplied by a complicated function of the eccentricity. Because most of the radiation is emitted near periastron, the GW radiation slowly circularizes the orbit. Also, because of the a^5 factor in the denominator, most of the energy is emitted just before coalescence. The gravitational waves carry off both energy (and thus mass) and angular momentum as the stars spiral in. I think in a typical NS/NS coalescence, the GW can carry off a significant fraction of a solar mass of energy.
It is the rotational energy of the system (angular momentum and energy are not interchangeable) that is being carried away by the energy in the gravitational waves. Thus the decrease in the orbital period. Because of mass-energy equivalence, this loss of rotational energy would be measurable as a decrease in the mass of the binary system.
Note, also, that the correct term is gravitational waves, not gravity waves. The distinction is important, because gravity waves are something else entirely, and unrelated to general relativity.
One could say it's gravitational potential energy. The system radiates, the two objects become closer together, meaning they have less gravitational potential energy (they also move faster, but the net is still a loss of energy).
I'm sure whether or not the emitted radiation also has a net angular momentum. I would naively guess usually not, but it's certainly conceivable.
Well, yes, if the angular momentum is decreasing, then certainly it must be carried away by the gravitational radiation.
Thank you for the replys guys, you have cured my fuzzy head :biggrin:
How does the gravity force formula apply now after the discovery of gravity waves?
What gravity force formula do you mean? Gravity is not a force in GR, and GR is the theory scientists use to analyze gravitational waves.
It doesn't, just like Coulomb's law didn't change with the discovery of Electromagnetic waves.
1. What is a binary system?
A binary system is a pair of stars that are gravitationally bound and orbit around a common center of mass.
2. What is a binary system inspiral?
Binary system inspiral is the process in which the two stars in a binary system spiral closer and closer together due to the loss of energy through gravitational waves.
3. Why is the Explore Binary System Inspiral w/ 1.5 Solar Masses important?
This specific binary system is important because it is a common scenario in the universe and studying it can help us better understand the process of binary system inspiral.
4. What is the significance of the 1.5 solar masses in this exploration?
The 1.5 solar masses represents the combined mass of the two stars in the binary system. This mass is important because it affects the rate of inspiral and the strength of gravitational waves emitted.
5. How is this exploration relevant to the field of astronomy?
Studying binary system inspiral with 1.5 solar masses can help us gain a better understanding of how gravitational waves work and how they can be detected. This knowledge can also help us in studying other binary systems and the evolution of stars in general.
  • Astronomy and Astrophysics
