Proving the Relationship Between \omega, \lambda and c
The discussion revolves around proving the relationship between frequency (ω), wavelength (λ), and the speed of light (c) through the equation dc/dω = (1/k)(1 - c/vg). The user initially struggles with the algebra involved in differentiating the variables, expressing confusion about their interdependence. After some attempts, they realize their mistake was a minor algebraic error. Ultimately, the user successfully solves the problem, indicating that the relationship can be established with careful manipulation of the equations. The thread highlights the importance of attention to detail in mathematical proofs.
mrausum
Show that:
\frac{dc}{d\omega}=\frac{1}{k}\left(1-\frac{c}{v_{g}}\right)
\frac{dc}{d\omega}=\frac{dc}{d\omega}\frac{d\omega}{d\omega}=\frac{dc}{d\omega}\frac{dck}{d\omega}=\frac{dc}{d\omega}k+\frac{dk}{d\omega}c=\frac{dc}{d\omega}k+\frac{c}{v_{g}}=\left\frac{1}{1-k}\right\frac{c}{v_{g}}
...Yeah, I have no clue. \omega, \lambda and c are all functions of each other, and I'm confused :(.
Nevermind, solved it. I was really close, I just made a stupid mistake with my algebra.
