Hammer Projectile Motion: Time and Range Calculations.
The discussion focuses on a physics problem involving projectile motion where a hammer slides down a roof at a constant speed of 4 m/s from a height of 10 m at a 30-degree angle. The calculated time to hit the ground is approximately 1.239 seconds, and the horizontal range is about 4.291 meters. A correction is noted in the equation used for vertical motion, emphasizing the need for the term .5gt^2 instead of .5gt. The calculations for both time and range are verified as correct, confirming the accuracy of the solution. Understanding these principles is essential for solving similar projectile motion problems.
joemama69
A worker on the roof of a house drops his hammer, which slides down the roof at a constand speed of 4 m/s. The roof makes an angle of 30 degrees with the horizontal, and its lowest point is 10 m from the ground.
A-find the time it takes to hit the ground
b- what is the range
v(x) = 4cos-30 = 3.464
v(y) = 4sin-30 = -2
Just want someone to verify my work
y = y(initial) + v(y)t + .5gt
0 = 10 - 2t - 4.9t, t = 1.239s
x = x(initial) + v(x)t
x = 3.464(1.239) = 4.291 m
Your solution is correct.
But in the equation
it should by
y = y(initial) + v(y)t + .5gt^2
