Hard? implicit differentiation
rook_b
Find d^2y/dx^2 in terms of x and y.
x^2y^2-2x=3
property rule, chain rule, quotient rule,
I can do this the long way, but there must be a shorter solution. Can I simplify it? I've found dy/dx=(-xy^2 +2x)/(2x^2y). but the derivative of that takes a ridiculous amount of steps. If there isn't a shorter way then I'll just take my time.
this is how i would simplify
(xy)^{2}-2x=3
there aren't that many steps, it only took me 3 steps, maybe you're doing something wrong, if you want show your steps and i'll be happy to help further.
OK thanks, that simplification made the first derivative easier and pointed out to me that my original calculation had a mistake. My math skills have quite a few holes. So now I have dy/dx= (-xy^2+1)/(x^2y) so is there another simplification I'm overlooking? If I differentiate that it's still a bit messy and I'm learning there is always an easier way... well sometimes.
Your answer for dy/dx in post #3 is correct. I'm not sure how you want to simplify this. You could write \frac{1-xy^2}{x^2y}=\frac{1}{x^2y}-\frac{y}{x} but I'm not sure that this is simpler to differentiate.
I'm wondering what "long way" you used. Straight forward implicit differentiation does seem that long to me!
x^2y^2- 2x= 3
Differentiating once:
2xy^2+ 2x^2yy'- 2= 0
Differenitiating again:
2y^2+ 4xyy'+ 4xyy'+ 2x^2(y')^2+ 2x^2yy"= 0
-2x^2yy"= 2y^2+ 8xyy'+ 2x^2(y')^2
Now divide by -2x^2y to get
-\frac{2y^2+ 8xyy'+ 2x^2(y')^2}{2x^2y}
Since the derivative will necessarily have "y" in it, I would see no reason to write y' as a function of x which I think is the "hard" part of what you did.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
