Hard kinematics problem: Block pushed onto a moving conveyor belt
The discussion revolves around solving a kinematics problem involving a block on a moving conveyor belt, focusing on the effects of friction and velocity components. Participants emphasize the importance of using the coefficient of friction, denoted as μ, even when not explicitly provided, to analyze the motion. They explore the relationship between the block's velocity and the forces acting on it, particularly in the belt's frame of reference. The conversation includes attempts to derive equations of motion and clarify the signs of velocity and acceleration components. Overall, the key takeaway is the need to carefully consider the frame of reference and the effects of friction on the block's motion.
IamVector
A block is pushed onto a conveyor belt. The belt
is moving at velocity v0 = 1 m/s, the block’s initial velocity
u0 = 2 m/s is perpendicular to the belt’s velocity. During its
subsequent motion, what is the minimum velocity of the block
with respect to the ground? The coefficient of friction is large
enough to prevent the block from falling off the belt.
hint given : we use the conveyor’s frame, but
as we are asked about the speed in lab frame, we need
to switch back to the lab frame. In the conveyor’s frame,
the velocity vector becomes shorter while preserving the
direction, i.e. can be represented as ⃗w = k ⃗w0, where its
initial value ⃗w0 = ⃗v0 −⃗u0 and the factor k takes numerical
values from 0 to 1. Hence, the velocity in the lab frame
⃗v = ⃗u0 + k ⃗w0: this is a vector connecting the right angle
of the right triangle defined by its catheti ⃗u0 and ⃗v0 with a
point on the hypotenuse; the specific position of this point
depends on the value of the factor k (which is a function
of time).
stuck on this question
If you are not given much information, then you have to use the little you are given. There must be some finite coefficient of friction. What can you do with that?
Likes IamVector
Welcome, IamVector!
It seems that this problem is a subtraction of vectors.
Could you post a diagram?
there is no finite coefficient of friction given does it have any relation with the velocities given ?? it is just stated that it is large enough to prevent it from falling off the belt
Okay, let the coefficient of friction be ##\mu##. Now it is given!
ok I will try the best I can
do I have to represent k in terms of friction coefficient and time??
You need the equatiion of motion in the belt frame, yes.
W = ((5^1/2)-µgt)?? so k = (1-((µgt)/5^1/2)
can you please explain me the hint given?it will be a great help
Forget about the ground frame for the moment. Can you give the components of the velocity in the belt frame?
-1i+2j ??
IamVector said:
-1i+2j ??
Come on! As a function of time.
-(1-µgt)i + ( 2-µgt)j ?
Friction doesn't know about ##x## and ##y## directions. It opposes motion uniformly. You may need to think about that.
Trying a slightly different approach...
You can follow the @PeroK approach and work this algebraicly. Or you can dispense with the numbers and coordinates for the moment and deal with it geometrically.
The decelleration has a total magnitude of ##\mu g##. Your proposed formula puts the angle of the frictional force at 45 degrees with total magnitude ##\sqrt{2} \mu g##. That is not right. You need for the two component forces to make the correct angle and the correct magnitude.
Proceeding with the geometric approach.
From the belt frame, you have this object arriving, at -1i + 2j just as you state. The only forces on the object are gravity, normal force and friction. Gravity and normal force cancel. It will follow a straight-line path at constant deceleration until it comes to a stop.
Likes PeroK
(-(1)i + ( 2)j) -μgt
The difficulty now is that you do not have a direction on the ##\mu g t## vector.
will it be unit vector * friction force??
If you want to keep working with components (as @PeroK surely intends) then you need to split that ##-\mu g t## into ##\hat{i}## and ##\hat{j}## components.
Time to apply some trig functions.
With the geometric approach, I would have you draw that (-1,2) velocity vector and imagine that you are searching for some lesser velocity vector along the same line.
The lesser velocity vector you are searching for is the one that you can add (vector addition) to the belt speed to minimize the magnitude of the resulting vector sum.
so angle between resultant and i component will be arctan(2/1) so I used it to find the components of friction force
-(-μgt/√5 )i+(-2μgt/√5)j??
I think you have a sign error there. A component of the frictional force should have the opposite sign to the corresponding component of the velocity.
(-μgt/√5 )i-(-2μgt/√5)j??
So we have a
Ummm. Check the signs on your velocity components against the signs on your acceleration components. Does friction cause acceleration or decelleration?
jbriggs444 said:
So we have a
(μgt/√5 )i-(2μgt/√5)j??
Yes, that looks right to me. However, you've lost the initial velocity components.
Or, perhaps, by now you've forgotten what you were setting out to calculate. We want a formula for component-wise velocity that starts out high at t=0 and ends up low some time later.
Just to explain the approach I was thinking about. In the belt frame, for which I'll use primed values.
The block starts at some initial speed ##u'## at some intial angle ##\theta'##. The speed at time ##t## is given by ##v' = u' - at##, where ##a## is the deceleration due to friction. ##a = \mu g##
The angle remains constant, so we have:
$$v'_x = -v'\sin \theta', \ \ v'_y = v'\cos \theta'$$
And now we can transform to the ground frame ...
Hint: ##v## is minimised when ##v^2## is minimised.
(-1+μgt/√5 )i-(2-2μgt/√5)j??
Likes jbriggs444
Ooops. That's a double negative there in the middle. You screwed up the signs again.
That's a good argument against folding the sign on a component into the plus sign between the components. Do all of your signs in the component values and you won't get so confused.
initial angle between belt velocity and block velocity??
  • #31
so now how do we convert into lab frame?? by using hint but what is the logic behind it??
  • #32
I've done too much for you already. The rules here are that we should only give hints.
You can work out what ##\theta'## is if you do your own diagram.
Whenever there are two frames, you need to think carefully about notation.
The hint was a general tip when you want to minimise a speed. Minimising ##v^2## avoids having to differentiate terms involving square roots. It's just a bit neater and quicker.
  • #33
sry
(-1+μgt/√5 )i+(2-2μgt/√5)j??
  • #34
Let's read through what @PeroK has written and try to decode the sign convention.
We know that we are using the belt frame from several hints. First, the block arrives at an angle. If we were using the ground frame, it would arrive purely crosswise. Second, we are using ##v'## to denote the velocity. One would expect to use unprimed velocities for the frame we really care about and primed velocities for the frame we are temporarily working in. Finally, we are told that the "angle remains constant". That only happens in the belt frame. In the ground frame, the object is going to be curving.
I am betting that the x-axis is laid out on the axis of the conveyer belt and the y-axis is laid out across the conveyer belt. We are notionally standing on the right side of the conveyer belt watching it move to the right in front of us. The positive x-axis extends to our right in the direction the belt is moving. The positive y-axis extends across the belt in front of us.
However, since we have adopted a frame of reference in which the belt is motionless, we are using primed coordinates. We have notionally stepped up onto the belt and are moving along with it.
An object enters the belt, passing between our two feet. It makes an angle ##\theta'## counter-clockwise from the y axis.
Now we check this interpretation. The x velocity of the object is ##-v' \sin \theta'##. Yes, that works out. we are measuring the angle theta counter-clockwise.
The y velocity of the object is ##v' \cos \theta'##. Yes, that works out the same way.
Now then you had asked:
As @PeroK has hinted, the angle that a trajectory makes will depend on who is doing the measuring.
If you were riding in a railroad car throwing a ball up and then catching it again, you would say that the ball is being thrown at an angle of 90 degrees relative to the car's motion -- purely vertical. But a passerby would say that the ball is thrown at some angle forward of the vertical.
That is why @PeroK was careful to label the angle ##\theta'## rather than ##\theta##. It is an angle measured from the belt frame.
As above, it appears to be the angle that the object's trajectory makes (in the belt frame) compared to a reference angle going straight across the belt.
Likes PeroK
  • #35
I think I need to learn more before solving these problems thank you for your efforts btw it will be a great help if you could kindly tell me your approach of doing maybe it will work out for me or you could explain me the hint provided and logic behind it I am really confused with that .
  • #36
You are going to need to show some effort or put some better focus into your questions. I am not going to simply shotgun hints until one sticks.
Likes PeroK
  • #37
I think my concepts are a bit weak this ques is from jaan kalda kinematics pdf I tried doing it to make my concepts strong to reach level of Olympiads question but I managed to do only first 5 rest are out of my range thanks for your help.
  • #38
btw any advice from your side on improving my conceptual knowledge will be a great help
  • #39
This is not an easy question. There are two things. One is notational technique. Look at the way that @jbriggs444 understood my notation and why I had used the variables I did. That's something to work on.
The other thing is not needing a one-step solution. Easy mechanics questions are a bit like doing chess puzzles where you need to find checkmate in 1-2 moves. A problem like this is more like finding a checkmate in 4-5 moves. You need to keep going with a line of thought, analysis and mathematics and see where it leads. And, judge when it's not leading anywhere and backtrack.
Both of these things require practice and a certain discipline to stick with an idea and think it through.
Likes jbriggs444
  • #40
thanks I will try it one more time
  • #41
A third point is being able to work algebraically. You could certainly plug the numbers in in this case. But, I find the more practice you get with the algebraic patterns the better.
My solution is just over a page of A4. About 15-20 lines. So, you'll have to stick with it. Unless you do something very clever, the answer won't come out in a few lines.
That said, I suspect there may be a very neat, quick solution to this. But, I don't see it.
  • #42
I may be streamlining out some steps with my intuition leading me helter skelter to a nice diagram. But the geometric approach allows a result to be read off almost immediately.
Likes PeroK
  • #43
ok thinking on it
  • #44
what is your approach??
Likes PeroK
  • #45
Look at post #20 in this thread.
Following the approach means being able to understand that shifting from the belt frame to the ground frame amounts to adding a fixed rightward velocity (1 m/s in this case) to everything.
  • #46
as you said to convert into lab frame I have to add 1m/s to everything I added it to my eq which will be equal to my velocity from lab frame(i think)
  • #47
Can we see what you have done so that we can critique and possibly guide?
  • #48
It's become a contest bewteen inspiration and geometric insight on the one hand and honest algebraic toil on the other!
Likes jbriggs444
  • #49
I think I got the answer! (μgt/√5 )i+(2-2μgt/√5)j got this equation after adding 1 then took its mod thus forming a quadratic in μgt now to find the min value of vector we need min value of quadratic so I find its vertex and took out its min value ie (4/5)^1/2 = (2)/(5^1/2)
  • #50
##\frac 2 {\sqrt 5} m/s## is the answer I get.
In general the minimum speed is ##v_b \cos \theta'##, where ##v_b## is the speed of the belt and ##\theta'## is the angle of motion relative to the belt.
