Harmonic Oscillator wave function
The discussion centers on calculating the uncertainty product ΔxΔp for a quantum harmonic oscillator using its ground state wave function. Participants clarify that to compute ΔxΔp, one must find the expectation values of x² and p², which involves integrating the wave function. The limits of integration are from -∞ to +∞, and since the integrand is an odd function, the expectation value of x is zero. After some calculations, it is confirmed that ΔxΔp equals ħ/2, aligning with the Heisenberg Uncertainty Principle. The conversation concludes with a participant successfully identifying and correcting an earlier miscalculation.
diegoarmando
Uncertainty - Harmonic Oscillator
The Wave function for the ground state of a quantum harmonic oscillator is
<br /> \psi=(\alpha/\pi)^{1/4}e^{-\alpha x^2/2}<br /> where \alpha = \sqrt{ mk/ \hbar^2}.
Compute \Delta x \Delta pknown:
Heisenberg Uncertainty Principle:
\Delta p \Delta x &gt;= \hbar/2
In order to compute \Delta x \Delta p, what do I need to do? any integral?
Well done - but I think that is already known to science.
Or did you have a further question about it?
My question is how to find \Delta x \Delta p
You'll want to find the expectation values of x^2 and p^2 (since the expectation values of x and p are zero), and take their square roots. These are your deltas. So yes, you have to integrate to find <psi|x^2|psi> and <psi|p^2|psi>.
Just to be pedantic, \Delta x^2 = \langle x^2 \rangle - \langle x \rangle^2. Just that in this case, \langle x \rangle = 0.
Thanks guys,
but how the <x> and <p> are zero, could you please help me for integral part, what is the limits of integral in this case?
The limits on the integral are +/- infinity. And both integrals have the general form of an integral of x*exp(-K*x^2). So the integrand is an odd function. It's integral is zero.
ok, I find &lt;x^2&gt; =1/2\alpha what should I do for <p^2>
p=-i*hbar ?
Uh, p=-i*hbar*d/dx. You need to apply that operator twice to psi since you are finding <psi|p^2|psi>. Your <x^2> looks good.
I found \Delta x \Delta p=\hbar/\sqrt {2}
which means \Delta x \Delta p is independent from the value of alpha, what do you think? somehow I think I should have gotten \Delta x \Delta p=\hbar/2
You did really well, except yes, you should have gotten hbar/2. I did. Can you find the missing sqrt(2)? I can check intermediate results if you want to post them.
Thanks for the reply, I think I found the missing sqrt(2)
Well done.
