Having problems evaluating definite integral
tjkubo
I'm trying to evaluate
\int_0^{2\pi} \frac{9-6\cos t}{5-4\cos t} dt \ .
I found that the antiderivative of the integrand is
F(x) = \frac{3}{2}x + \tan^{-1} \left(3\tan\frac{x}{2} \right)
so using the FTC, the integral should be
F(2\pi)-F(0)=3\pi
But using a calculator to evaluate the integral yields 4\pi.
What am I doing wrong here?
Hint: tan-1 0 is not always equal to 0.
I don't understand what you mean. If tan-1 x were multivalued, then it would not be a function, so I implicitly restricted tan-1 x to its principal branch.
F(2\pi)-F(0)=3\pi
You need to worry about whether or not the hypotheses of the fundamental theorem of calculus hold; that is, whether or not \int_0^{2 \pi} f(x) \, dx = F(2\pi) - F(0) actually holds (where F is an antiderivative of f). If F(x) sweeps over points arising from different branches of 'arctan' as x goes from 0 to 2π, you might run into trouble. To be safe, break up the integral as I = I_1 + I_2, where x goes from 0 to π in the first integral and from π to 2π in the second; then change variables to x = π + y in the second integral, so you again have an integral from 0 to π.
RGV
Aren't the hypotheses of the FTC just that F is differentiable and F'=f? These seem to hold for the function I gave, so I don't see exactly where the problem is.
Yes, you need F to be differentiable.
If \displaystyle F(x) = \frac{3}{2}x + \tan^{-1} \left(3\tan\frac{x}{2} \right)\,, notice that F has jump discontinuities at x = (2k+1)π. In other words, F(x) is not differentiable when x is an odd integer multiple of π.
This requires you to break up the integral as has been suggested.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
