Bystander said:
Looks like homework to me; what have you done so far with it?
I have attached a document with my work so far. And here are the variables I am using in my work.
Q = total heat flux = zero
Qs = shortwave solar radiation (150 W m^-2)
Qb = net longwave infrared radiation (50 W m^-e) and is derived from Qb,out - Qb,in
Qh = sensible heat flux (10 W m^-2)
Qe = latent heat flux (90 W m^-2)
Direction of fluxes are: Qs into the ocean ; Qb,h,e are out of the ocean
Pa = density of air (1.5 kg/m^3)
Ce = latent heat transfer coefficient (1.35 x 10^-3)
Ch = sensible heat transfer coefficient (0.9 x 10^-3
Tsst = sea surface temperature
T10 = temperature of air 10 meters above surface
U10 = wind speed at 10 meters above the sea surface
L = latent heat of evaporation (2.5 x 10^6 J/kg)
Qsst = specific humidity of air (kg water vapor/kg air)
Q10 = specific humidity of air 10 meters above surface (kg water vapor/kg air)
I should also rewrite the question to state it exactly as it is...
"Mean seawater temperatures vary greatly throughout the year in the Baltic Sea with mean water temperatures as high as 20C in August and as low as 3C in February. For a patch of water with a depth of 10 meters, what is the net heat flux lost (in W m^-2) to the atmosphere from August to February? (Ignore thermal expansion)".
Also, I am working under the assumption that to ignore thermal expansion means that the water parcel can be brought adiabatically to the surface.
The gist of it is that I am trying to move from working with a heat budget for the ocean, which involves fluxes in and out, to evaluating just those parameters which have a direction of out of the ocean and into the atmosphere. I think that I have a decent start, so far..
Again, attached is where I am at at this point
