How Does Gas Pressure Affect Heat Conduction in a Vacuum Flask?
Fek
A vacuum flask of radius r and length l consists of two concentric cylinders separated by a narrow gap containing a gas at pressure 10^-2 Nm^-2. The liquid in the flask is at 60 degrees Celcius and the air outside is at 20 degrees celcius. Estimate the rate of heat loss by conduction.
κ = 1/3 Cmolecule n λ <v>
λ = ( sqrt(2) * n * σ) ^ -1
p = 1/3 nm <v2>
pV = nkbT
J = - κ ∇T
where n is molecules per unit volume.
κ is independent of pressure so the equation is still valid.
Cv per mol is 3/2 R for an ideal gas. So if I divide by avagadro's I will get heat capacity per molecule.
<v> = sqrt( 8KBT / m pi)
The gas in the "vacuum" is air, so mainly nitrogen, so m = 14.
For the temperature of the "vacuum" gas, as it is definitely between 293K and 333K it does not matter exactly.
So now we just need the mean free path. We can estimate the collision cross section as 2a^2 where a is the atomic radius.
Then we can find n either by using the equation for pressure or the ideal gas equation
n = p / KBT
Still left with ∇T unknown which seems like a dead end.
You're trying to find J. Do you know how to determine ∇T if the gap is small and the temperature is assumed to vary linearly with radius? How does the mean free path compare with the gap between the cylinders?
Chet
Thanks for your response Chet.
∇T ≈ ΔT / s , where s is the gap between cylinders if we assume that ∇T is constant. However s is not given.
The expression for κ assumes the mean free path is much less than the size of the container, so the molecules collide with each other much more frequently than the container - I now see that this is not the case we can't use that expression.
However without using it I am struggling to see a method.
I suppose you could assume that the particles simply bounce back and forth across the gap and gain/lose internal energy each time they come into contact with a wall and transfer it that way. However it would be difficult to estimate the energy gained in each contact and the route between walls taken by the particle.
I also know Newton's Law of cooling: AH = hA ΔT , but I have not learned about what determines h.
That's what I was afraid of. Sorry, wish I could help you, but I don't have any experience in this area.
Chet
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
