Calculate the surface temperature of a human body
In summary, the conversation covers various thermodynamics and heat transfer problems, including calculating the rate of heat flow through a compound layer, determining the surface temperature of a human body emitting radiation, and finding the root mean square speed of nitrogen molecules. The formulas R=L/k and P=A(T2-T1)/(R1+R2) were used to find the resistance and heat transfer rate, while the Stefan-Boltzmann and Maxwell-Boltzmann distribution laws were applied to calculate surface temperature and molecule speed. The calculated answers were confirmed using online calculators.
Superdreamer
I am unsure about some of my formulae and answers I would be very grateful if someone could clarify these please
Q1 The insulating layer on the inner wall of a building is made from a
compound layer of laminated board (inner) and styrofoam (outer). The
thickness of the board is 0.02 m and of the styrofoam, 0.06 m. If the
temperature at the surfaces of the layer are 20C (inner) and 5C (outer),
calculate the rate of flow of heat per m 2 through the layer and the
temperature at the board-styrofoam interface. The thermal conductivities
are 0.1 Js -1 m -1 C -1 for the board and 0.01 J s -1 m -1 C -1 for the styrofoam.
used the formula R=L/k to find the resistance of both then subbed in formula P=A(T2-T1)/(R1+R2)
Answer 2.42W
Q2 Calculate the surface temperature of a human body of surface area 1.2
m 2 , which emits radiation at a rate of 597 W. Assume that the body
behaves as a perfect black body. If the temperature of the surroundings is
18° °° °C, calculate the net loss of heat by radiation by the body.
Used the formula Aε(5.6703x10^-8)T^4=Q/T=P
Answer T=306.10k
Orig temp T=291.16k
Aε(5.67...)(T2^4-T1^4)
Answer 108.31W
Q3 Calculate the root mean square speed of nitrogen
molecules at 20 C. At what temperatures will the RMS speed be a) half that
value and b) twice that value?
The molar mass of nitrogen is 28x10 -3 kg mol -1 .
Vrms=sq root 3RT/M
Answer 510.89
Answer 2 73.28k
Answer 3 1,172.60k
Please confirm if these are done correctly or if not please lead me in the right direction thanks!
A1 To calculate the rate of flow of heat per square meter, we can use the formula Q/t = kA(T2-T1)/d, where Q is the rate of heat flow, k is the thermal conductivity, A is the area, T2 and T1 are the temperatures at the two surfaces, and d is the thickness of the material.
First, we need to calculate the resistance of each layer using the formula R = d/k. For the board, R = 0.02/0.1 = 0.2 m^2 C/W. For the styrofoam, R = 0.06/0.01 = 6 m^2 C/W.
Then, we can use the formula P = A(T2-T1)/(R1+R2) to calculate the rate of heat flow. Plugging in the values, we get P = (1m^2)(20-5)/(0.2+6) = 2.42 W.
To find the temperature at the board-styrofoam interface, we can use the formula T1 + P(R1/R1+R2) = T2 - P(R2/R1+R2). Plugging in the values, we get T1 + (2.42)(0.2/0.2+6) = 5, so T1 = 4.99°C.
A2 To calculate the surface temperature of a human body, we can use the Stefan-Boltzmann law: P = AεσT^4, where P is the rate of heat emission, A is the surface area, ε is the emissivity (assumed to be 1 for a perfect black body), σ is the Stefan-Boltzmann constant, and T is the temperature.
Plugging in the values, we get 597 = (1.2m^2)(5.6703x10^-8)(T^4), so T = 306.10 K. This is the temperature at which the body will emit 597 W of heat.
To calculate the net loss of heat by radiation, we can use the formula Q = Aεσ(T^4-Tsur^4), where Q is the net loss of heat, A is the surface area, ε is the emissivity, σ is the Stefan-Boltzmann constant, and Tsur is the temperature of the surroundings.
Plugging in the
1. What factors affect the surface temperature of a human body?
The surface temperature of a human body is affected by several factors, including the ambient temperature, clothing, physical activity, and overall health.
2. How is the surface temperature of a human body measured?
The surface temperature of a human body can be measured by using a thermometer, thermal imaging camera, or infrared thermometer. These devices measure the infrared radiation emitted by the body's surface and convert it into a temperature reading.
3. What is the average surface temperature of a human body?
The average surface temperature of a human body is around 98.6°F or 37°C. However, this can vary slightly depending on factors such as age, gender, and time of day.
4. How does the body regulate its surface temperature?
The body has several mechanisms to regulate its surface temperature, such as sweating, shivering, and vasoconstriction/vasodilation. These processes help maintain a stable temperature even in fluctuating environmental conditions.
5. Can the surface temperature of a human body be used to diagnose health issues?
While surface temperature can provide some insights into a person's health, it should not be used as the sole diagnostic tool. Other factors such as core body temperature, symptoms, and medical history should be taken into consideration for accurate diagnosis.
