Calculating Heat Energy & Temperature Change: Seeking Help!
To calculate the heat energy required to melt the iceberg, one must consider its volume, density, and the heat of fusion for water. For the second problem, determining the time to raise the object's temperature involves calculating the energy needed based on its mass, specific heat, and the power output of the dryer. The discussion emphasizes the importance of understanding specific heat and heat of fusion concepts, suggesting that reviewing relevant textbook materials or online resources can aid in solving these problems. Engaging with these principles is crucial for grasping the calculations involved. Mastery of these topics can significantly enhance performance in the class.
Vigo
1.) An iceberg's volume is 2*10^6 m^3. If the temperature of the iceberg is is 250 K and the density is .9998 g/cm^3, how much heat energy would be required to competely melt it?
2.) An object weighs 500 grams and has a specific heat of 2 Joules/g C. The object absorbs 40% of the output of a 1200 watt dryer. How long will it take to raise the object's temperature from -10 C to 20 C?
Please help me with these problems. My teacher gave them to us for extra credit because he hasn't taught us how to do them. I could really use some extra credit in that class. Thanks.
I would suggest that you read ahead in the textbook or the web (eg. http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/phase.html#c1")on specific heat and "heat of fusion" of water first and then try them.
AM
