Does Adding a Finned Heat Sink Justify Improved Heat Transfer Rates?
The discussion revolves around estimating the heat transfer rates from a hot electronic component with and without a finned heat sink. The user seeks to understand the relevant equations rather than a complete solution. Key parameters include a chip size of 10 mm x 10 mm, a convective heat transfer coefficient of 50 W/m²K, and a finned heat sink made of aluminum with specific dimensions and thermal conductivity. The inquiry focuses on whether the addition of the heat sink justifies improved heat transfer rates. Theoretical insights into heat sink design are also referenced for further exploration.
acox20
Hey, long time reader, new user. I have a probably simple fin question. If you all don't mind.
I honestly just need to nail down the equations. Don't quite need a solution.
A fan blows air over the top surface of a hot electronic component (size of 10 mm x 10 mm) with an average convective heat transer of 50 W.m^2k. If a longitundinal finned heat sink is added to this top surface, estimate the ratio of heat transfer rates from the chip surface to air with and without heatsink. The base of the heat sink is 1 mm think and has the same size as the chip. The heat sink has 12 rectangular fins, each .5 mm thick and 10 mm wide. The total hight of the heat sink including the base and the fines is 16mm. Both air and chip top surface tempertures are fixed and known. I am supposed to assume that the heat sink is made of an alluminum alloy with a termal conductivity of 160 W/mK and that the fins are infinitely long. Does it justify using the finned heat sink in this case? Thank you for you efforts.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
