Heat Transfer From Resistance Element to Metal Component
A user seeks a high-temperature thermal adhesive to transfer heat from Nichrome coils to a stainless steel component, aiming to reach 175 degrees Celsius. They have not found suitable consumer options and are looking for alternatives. Recommendations include thermally conductive epoxies commonly used in electronics manufacturing. However, the user encountered issues with suppliers like Masterbond, which only sell in bulk to businesses. Effective heat transfer solutions remain a key focus of the discussion.
normynormand
Hello Physics Forums!
My problem is as follows. I have a device that produces heat via Nichrome coils. I want to heat another small piece of metal (in this case stainless steel) with those Nichrome coils. I need to reach 175 degrees C, and so far I haven't found a readily available thermal adhesive that will work in my temperature range. Is there a high temperature thermal adhesive available to consumers that I could use? Any suggestions on another way to effectively transfer the heat from the coils to my small metal component?
Thanks in advance for your help!
There are a number of thermally conductive epoxys available that are used primarily in electronics manufacturing. This web site has some examples, but there are many others.
Thanks for the reply. I tried Masterbond, however they only sell in large quantities to businesses.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
